I have some half-bridge ICs, L6384E's, that I'm having the darnest time getting to work. I've created the circuit on page 1 of the datasheet and checked over the wiring several times. So I don't think I have a simple wiring error. The symptoms are that HVG and LVG are always 0V, not matter what signal I put on IN. This would seem to imply the UVLO feature is activating for some reason, but my VCC is a nice steady 12V.
I'm at the point where I just want to build the simplest possible circuit that will prove the drivers work at all. Here's what I'm thinking:
Pin 1: IN -> GND
Pin 2: VCC -> 12V (through a small resistor)
Pin 3: DT/SD -> 56k resistor to GND
Pin 4: VSS -> GND
And leave 5 through 8 floating. HVG and LVG are always opposite each other to facilitate complimentary PWM (see fig 3). So if IN is GND, then LVG should go high. Would that work? Or does the internal circuity of the driver require the rest of the pins to be connected for anything to happen at all?
Pin 1: IN -> GND
Pin 4: VSS -> GND
