Sine table code in c
Speaking of devices with built-in D2A, some of the 16F1700 series devices include not only an 8-bit or 10-bit D2A but an Op-Amp that can be driven by the D2A.
While I haven't tried it yet, I think these devices might be a good choice for a nice DDS Signal Generator Design.
Speaking of DDS Signal Generators, I found some unfinished experimental code from 2011 for a PWM DDS Signal Generator. It looks like I was using a 16F device with a 20-cycle PWM period and DDS loop with a 32-MHz clock for a 400-kHz PWM and DDS loop frequency to produce 80 PWM steps. It also looks like I used a 10-bit 256 step sine table with PWM duty cycle values stored as words which, when read, would be written directly to the CCPR1L and CCP1CON registers. I suspect I was looking at different ways to implement a fast DDS loop. Here's a couple excerpts;
;  main.loop                                                      *
        banksel EEADRL          ; bank 3                          |03
        movlw   high(sine)      ; sine table address high         |03
        movwf   EEADRH          ;                                 |03
        clrf    EEADRL          ; accum+3                         |03
        clrf    accum+1         ;                                 |03
        clrf    accum+0         ;                                 |03
        bcf     EECON1,CFGS     ; CFGS = 0 (Flash)                |03
        bsf     EECON1,EEPGD    ; EEPGD = 1 (Flash)               |03
        movlw   high(CCPR1L)    ; hi(0x291)                       |03
        movwf   FSR0H           ;                                 |03
        movlw   low(CCPR1L)     ; lo(0x291)                       |03
        movwf   FSR0L           ;                                 |03
        movlw   high(CCP1CON)   ; hi(0x293)                       |03
        movwf   FSR1H           ;                                 |03
        movlw   low(CCP1CON)    ; lo(0x293)                       |03
        movwf   FSR1L           ;                                 |03
;  20 cycle (2.5 us) 32-bit 400-kHz DDS loop (32 MHz clock)
ddsloop
        movf    phase+0,W       ;                                 |03
        addwf   accum+0,F       ;                                 |03
        movf    phase+1,W       ;                                 |03
        addwfc  accum+1,F       ;                                 |03
        movf    phase+2,W       ;                                 |03 <-
        addwfc  accum+2,F       ;                                 |03 <-
        movf    phase+3,W       ;                                 |03
        addwfc  EEADRL,F        ; accum+3 (sine array index)      |03
        bsf     EECON1,RD       ; read into EEDATH & EEDATL       |03
        nop                     ; required nop                    |03
        movf    EEDATH,W        ; the b7-b2 duty cycle bits       |03
        movwf   INDF0           ; CCPR1L = EEDATH                 |03
        movf    EEDATL,W        ; the b1-b0 duty cycle bits       |03
        movwf   INDF1           ; CCP1CON = EEDATL                |03
        nop                     ;                                 |03
        nop                     ;                                 |03
        btfss   INTCON,IOCIF    ; switch IOC? yes, skip, else     |03
        bra     ddsloop         ;                                 |03
;  duty cycle bits are placed in each 14 bit array element using
;  pattern '--765432 xx10xxxx' with CCP1CON register bits placed
;  in the 'x' bit positions.  This allows writing the CCPR1L and
;  the CCP1CON registers directly from EEDATH and EEDATL.
        radix   dec
sinprep macro   dcy
        dw     (dcy>>2)*256 | (((dcy%4)<<4)|12)
        endm
        org     0x700
sine
        sinprep(039)            ; 000  +0
        sinprep(040)            ; 001  +0.24541229e-1
        sinprep(041)            ; 002  +0.49067674e-1
        sinprep(042)            ; 003  +0.73564564e-1
        sinprep(043)            ; 004  +0.9801714e-1
        sinprep(044)            ; 005  +0.12241068
        sinprep(045)            ; 006  +0.14673047
        sinprep(046)            ; 007  +0.17096189
        sinprep(047)            ; 008  +0.19509032
        sinprep(048)            ; 009  +0.21910124
        sinprep(049)            ; 010  +0.24298018
        sinprep(050)            ; 011  +0.26671276
        sinprep(050)            ; 012  +0.29028468
        sinprep(051)            ; 013  +0.31368174
        sinprep(052)            ; 014  +0.33688985
        sinprep(053)            ; 015  +0.35989504
        sinprep(054)            ; 016  +0.38268343
        sinprep(055)            ; 017  +0.40524131
        sinprep(056)            ; 018  +0.42755509
        sinprep(057)            ; 019  +0.44961133
        sinprep(058)            ; 020  +0.47139674
        sinprep(058)            ; 021  +0.49289819
        sinprep(059)            ; 022  +0.51410274
        sinprep(060)            ; 023  +0.53499762
        sinprep(061)            ; 024  +0.55557023
        sinprep(062)            ; 025  +0.57580819
        sinprep(063)            ; 026  +0.5956993
        sinprep(063)            ; 027  +0.61523159
        sinprep(064)            ; 028  +0.63439328
        sinprep(065)            ; 029  +0.65317284
        sinprep(066)            ; 030  +0.67155895
        sinprep(066)            ; 031  +0.68954054
        sinprep(067)            ; 032  +0.70710678
        sinprep(068)            ; 033  +0.72424708
        sinprep(068)            ; 034  +0.74095113
        sinprep(069)            ; 035  +0.75720885
        sinprep(070)            ; 036  +0.77301045
        sinprep(070)            ; 037  +0.78834643
        sinprep(071)            ; 038  +0.80320753
        sinprep(071)            ; 039  +0.81758481
        sinprep(072)            ; 040  +0.83146961
        sinprep(072)            ; 041  +0.84485357
        sinprep(073)            ; 042  +0.85772861
        sinprep(073)            ; 043  +0.87008699
        sinprep(074)            ; 044  +0.88192126
        sinprep(074)            ; 045  +0.8932243
        sinprep(075)            ; 046  +0.90398929
        sinprep(075)            ; 047  +0.91420976
        sinprep(075)            ; 048  +0.92387953
        sinprep(076)            ; 049  +0.9329928
        sinprep(076)            ; 050  +0.94154407
        sinprep(077)            ; 051  +0.94952818
        sinprep(077)            ; 052  +0.95694034
        sinprep(077)            ; 053  +0.96377607
        sinprep(077)            ; 054  +0.97003125
        sinprep(078)            ; 055  +0.97570213
        sinprep(078)            ; 056  +0.98078528
        sinprep(078)            ; 057  +0.98527764
        sinprep(078)            ; 058  +0.98917651
        sinprep(078)            ; 059  +0.99247953
        sinprep(078)            ; 060  +0.99518473
        sinprep(078)            ; 061  +0.99729046
        sinprep(078)            ; 062  +0.99879546
        sinprep(078)            ; 063  +0.99969882
        sinprep(079)            ; 064  +1
        sinprep(078)            ; 065  +0.99969882
        sinprep(078)            ; 066  +0.99879546
        sinprep(078)            ; 067  +0.99729046
        sinprep(078)            ; 068  +0.99518473
        sinprep(078)            ; 069  +0.99247953
        sinprep(078)            ; 070  +0.98917651
        sinprep(078)            ; 071  +0.98527764
        sinprep(078)            ; 072  +0.98078528
        sinprep(078)            ; 073  +0.97570213
        sinprep(077)            ; 074  +0.97003125
        sinprep(077)            ; 075  +0.96377607
        sinprep(077)            ; 076  +0.95694034
        sinprep(077)            ; 077  +0.94952818
        sinprep(076)            ; 078  +0.94154407
        sinprep(076)            ; 079  +0.9329928
        sinprep(075)            ; 080  +0.92387953
        sinprep(075)            ; 081  +0.91420976
        sinprep(075)            ; 082  +0.90398929
        sinprep(074)            ; 083  +0.8932243
        sinprep(074)            ; 084  +0.88192126
        sinprep(073)            ; 085  +0.87008699
        sinprep(073)            ; 086  +0.85772861
        sinprep(072)            ; 087  +0.84485357
        sinprep(072)            ; 088  +0.83146961
        sinprep(071)            ; 089  +0.81758481
        sinprep(071)            ; 090  +0.80320753
        sinprep(070)            ; 091  +0.78834643
        sinprep(070)            ; 092  +0.77301045
        sinprep(069)            ; 093  +0.75720885
        sinprep(068)            ; 094  +0.74095113
        sinprep(068)            ; 095  +0.72424708
        sinprep(067)            ; 096  +0.70710678
        sinprep(066)            ; 097  +0.68954054
        sinprep(066)            ; 098  +0.67155895
        sinprep(065)            ; 099  +0.65317284
        sinprep(064)            ; 100  +0.63439328
        sinprep(063)            ; 101  +0.61523159
        sinprep(063)            ; 102  +0.5956993
        sinprep(062)            ; 103  +0.57580819
        sinprep(061)            ; 104  +0.55557023
        sinprep(060)            ; 105  +0.53499762
        sinprep(059)            ; 106  +0.51410274
        sinprep(058)            ; 107  +0.49289819
        sinprep(058)            ; 108  +0.47139674
        sinprep(057)            ; 109  +0.44961133
        sinprep(056)            ; 110  +0.42755509
        sinprep(055)            ; 111  +0.40524131
        sinprep(054)            ; 112  +0.38268343
        sinprep(053)            ; 113  +0.35989504
        sinprep(052)            ; 114  +0.33688985
        sinprep(051)            ; 115  +0.31368174
        sinprep(050)            ; 116  +0.29028468
        sinprep(050)            ; 117  +0.26671276
        sinprep(049)            ; 118  +0.24298018
        sinprep(048)            ; 119  +0.21910124
        sinprep(047)            ; 120  +0.19509032
        sinprep(046)            ; 121  +0.17096189
        sinprep(045)            ; 122  +0.14673047
        sinprep(044)            ; 123  +0.12241067
        sinprep(043)            ; 124  +0.9801714e-1
        sinprep(042)            ; 125  +0.73564563e-1
        sinprep(041)            ; 126  +0.49067674e-1
        sinprep(040)            ; 127  +0.24541228e-1
        sinprep(039)            ; 128  -0.41020686e-9
        sinprep(038)            ; 129  -0.24541229e-1
        sinprep(037)            ; 130  -0.49067675e-1
        sinprep(036)            ; 131  -0.73564564e-1
        sinprep(035)            ; 132  -0.98017141e-1
        sinprep(034)            ; 133  -0.12241068
        sinprep(033)            ; 134  -0.14673047
        sinprep(032)            ; 135  -0.17096189
        sinprep(031)            ; 136  -0.19509032
        sinprep(030)            ; 137  -0.21910124
        sinprep(029)            ; 138  -0.24298018
        sinprep(028)            ; 139  -0.26671276
        sinprep(028)            ; 140  -0.29028468
        sinprep(027)            ; 141  -0.31368174
        sinprep(026)            ; 142  -0.33688985
        sinprep(025)            ; 143  -0.35989504
        sinprep(024)            ; 144  -0.38268343
        sinprep(023)            ; 145  -0.40524131
        sinprep(022)            ; 146  -0.42755509
        sinprep(021)            ; 147  -0.44961133
        sinprep(020)            ; 148  -0.47139674
        sinprep(020)            ; 149  -0.49289819
        sinprep(019)            ; 150  -0.51410274
        sinprep(018)            ; 151  -0.53499762
        sinprep(017)            ; 152  -0.55557023
        sinprep(016)            ; 153  -0.57580819
        sinprep(015)            ; 154  -0.5956993
        sinprep(015)            ; 155  -0.61523159
        sinprep(014)            ; 156  -0.63439328
        sinprep(013)            ; 157  -0.65317284
        sinprep(012)            ; 158  -0.67155896
        sinprep(012)            ; 159  -0.68954055
        sinprep(011)            ; 160  -0.70710678
        sinprep(010)            ; 161  -0.72424708
        sinprep(010)            ; 162  -0.74095113
        sinprep(009)            ; 163  -0.75720885
        sinprep(008)            ; 164  -0.77301045
        sinprep(008)            ; 165  -0.78834643
        sinprep(007)            ; 166  -0.80320753
        sinprep(007)            ; 167  -0.81758481
        sinprep(006)            ; 168  -0.83146961
        sinprep(006)            ; 169  -0.84485357
        sinprep(005)            ; 170  -0.85772861
        sinprep(005)            ; 171  -0.87008699
        sinprep(004)            ; 172  -0.88192126
        sinprep(004)            ; 173  -0.8932243
        sinprep(003)            ; 174  -0.90398929
        sinprep(003)            ; 175  -0.91420976
        sinprep(003)            ; 176  -0.92387953
        sinprep(002)            ; 177  -0.9329928
        sinprep(002)            ; 178  -0.94154407
        sinprep(001)            ; 179  -0.94952818
        sinprep(001)            ; 180  -0.95694034
        sinprep(001)            ; 181  -0.96377607
        sinprep(001)            ; 182  -0.97003125
        sinprep(000)            ; 183  -0.97570213
        sinprep(000)            ; 184  -0.98078528
        sinprep(000)            ; 185  -0.98527764
        sinprep(000)            ; 186  -0.98917651
        sinprep(000)            ; 187  -0.99247953
        sinprep(000)            ; 188  -0.99518473
        sinprep(000)            ; 189  -0.99729046
        sinprep(000)            ; 190  -0.99879546
        sinprep(000)            ; 191  -0.99969882
        sinprep(000)            ; 192  -1
        sinprep(000)            ; 193  -0.99969882
        sinprep(000)            ; 194  -0.99879546
        sinprep(000)            ; 195  -0.99729046
        sinprep(000)            ; 196  -0.99518473
        sinprep(000)            ; 197  -0.99247953
        sinprep(000)            ; 198  -0.98917651
        sinprep(000)            ; 199  -0.98527764
        sinprep(000)            ; 200  -0.98078528
        sinprep(000)            ; 201  -0.97570213
        sinprep(001)            ; 202  -0.97003125
        sinprep(001)            ; 203  -0.96377607
        sinprep(001)            ; 204  -0.95694034
        sinprep(001)            ; 205  -0.94952818
        sinprep(002)            ; 206  -0.94154406
        sinprep(002)            ; 207  -0.9329928
        sinprep(003)            ; 208  -0.92387953
        sinprep(003)            ; 209  -0.91420976
        sinprep(003)            ; 210  -0.90398929
        sinprep(004)            ; 211  -0.8932243
        sinprep(004)            ; 212  -0.88192126
        sinprep(005)            ; 213  -0.87008699
        sinprep(005)            ; 214  -0.85772861
        sinprep(006)            ; 215  -0.84485356
        sinprep(006)            ; 216  -0.83146961
        sinprep(007)            ; 217  -0.81758481
        sinprep(007)            ; 218  -0.80320753
        sinprep(008)            ; 219  -0.78834643
        sinprep(008)            ; 220  -0.77301045
        sinprep(009)            ; 221  -0.75720885
        sinprep(010)            ; 222  -0.74095112
        sinprep(010)            ; 223  -0.72424708
        sinprep(011)            ; 224  -0.70710678
        sinprep(012)            ; 225  -0.68954054
        sinprep(012)            ; 226  -0.67155895
        sinprep(013)            ; 227  -0.65317284
        sinprep(014)            ; 228  -0.63439328
        sinprep(015)            ; 229  -0.61523159
        sinprep(015)            ; 230  -0.5956993
        sinprep(016)            ; 231  -0.57580819
        sinprep(017)            ; 232  -0.55557023
        sinprep(018)            ; 233  -0.53499762
        sinprep(019)            ; 234  -0.51410274
        sinprep(020)            ; 235  -0.49289819
        sinprep(020)            ; 236  -0.47139674
        sinprep(021)            ; 237  -0.44961133
        sinprep(022)            ; 238  -0.42755509
        sinprep(023)            ; 239  -0.40524131
        sinprep(024)            ; 240  -0.38268343
        sinprep(025)            ; 241  -0.35989504
        sinprep(026)            ; 242  -0.33688985
        sinprep(027)            ; 243  -0.31368174
        sinprep(028)            ; 244  -0.29028468
        sinprep(028)            ; 245  -0.26671276
        sinprep(029)            ; 246  -0.24298018
        sinprep(030)            ; 247  -0.21910124
        sinprep(031)            ; 248  -0.19509032
        sinprep(032)            ; 249  -0.17096189
        sinprep(033)            ; 250  -0.14673047
        sinprep(034)            ; 251  -0.12241067
        sinprep(035)            ; 252  -0.9801714e-1
        sinprep(036)            ; 253  -0.73564563e-1
        sinprep(037)            ; 254  -0.49067674e-1
        sinprep(038)            ; 255  -0.24541228e-1
That same source file includes some notes for a DDS Signal Generator engine using a 20-pin 18F14K22 driving an 8-bit R2R ladder that might be interesting to someone;
;  additional DDS musings                                         *
;  use an 18F14K22 (64-MHz), a 32 cycle (500-kHz) DDS loop, and
;  25.575 bit accumulator and phase variables for a 0.01-Hz DDS
;  frequency resolution (log500000*100/log2).  subtract phase
;  offset each loop and add 500000*100 on accumulator underflow
;  then use upper 9.575 accumulator bits (b25..b16) as an index
;  into a 763 byte (2^9.575) sine array.
;  stuff 'phase' offset variable with frequency*100 values (use
;  75000 for 750.00-Hz, 104005 for 1040.05-Hz, etc).  consider
;  limiting upper frequency to 16 samples per cycle (500000/16)
;  which is 31250.00 Hz.  Experiment to determine lower limit.
        radix   dec
dds64
        movf    phase+0,W       ; subtract phase offset from
        subwf   accum+0,F       ; the phase accumulator
        movf    phase+1,W       ;
        subwfb  accum+1,F       ; accum bits b15..b08
        movf    phase+2,W       ;
        subwfb  TBLPTRL,F       ; accum bits b23..b16
        movf    phase+3,W       ;
        subwfb  TBLPTRH,F       ; accum bits b25..b24
 ;  add 500000*100 to accumulator on accumulator underflow
        movlw   500000*100%0x0000100
        btfsc   TBLPTRH,7       ; negative? no, skip, else
        addwf   accum+0,F       ;
        movlw   500000*100/0x0000100
        addwfc  accum+1,F       ;
        movlw   500000*100/0x0010000
        addwfc  TBLPTRL,F       ;
        movlw   500000*100/0x1000000
        addwfc  TBLPTRH,F       ;
        movf    tbladdr,W       ; tables 1000, 1400, 1800, 1C00
        iorwf   TBLPTRH,F       ; select proper table
        tblrd*                  ; uses 2 cycles
        movff   TABLAT,PORTC    ; 8-bit sine value
        xorwf   TBLPTRH,F       ; restore accumulator value
        nop                     ;
        nop                     ;
        nop                     ;
        bra     dds64           ; must be exactly 32 cycle loop
DDS Signal Generator Design Kind of what I want make I don't have a Signal Generator I've put together some with a timer but I been playing with something that needs a sine wave.
And I want make some tools to mess around with.
Figured now be the time to really do some stuff I been wanting to do.
I have a 16f that has a dac and that wave making I really like to give it ago at this.
I built the one out of the EPE magazine... It still serves me very well today
Sitting on top of my old storage scope...
