Over the years I've made several op-amp based electret mic preamps, running from 9v batteries, boosted AA batteries or 5V. These are used for general voice, such as skype/MSN/gaming, and sometimes for recording acoustic instruments like guitar and piano. I've found it straight forward to vary the gain and frequency response of these amps, but for a cheaper desk mic I would like to try a single transistor amp - with some form of gain control.
Although Google has many examples, many have quite a high gain. Considering the mic input for your average soundcard is pretty poor, I'd rather not use the on-board '20dB boost' but use an external one instead. Often even this gain is not enough, so a controllable amp from say 16 to 30dB would be ideal. It should be powered by USB, for which I have made a transistor-based filter to give around 4.3V thats pretty damn clean. (one could also use an LDO set to 4-4.5V, they generally do quite well at filtering power supplies).
After tinkering with LTspice to work out exactly whats going on in a single transistor amp, it seems that changing/varying the emitter resistor in this circuit does the job, albeit in a non-linear way. I've also attempted to get LTspice to calculate the THD of the circuit, as well as the noise.
I've also noticed many circuits have a cap on the emitter, is this simply to boost the gain? Because I'm not after a massive gain, just has to be variable. So, any improvements to this are welcome!! Its a combination of application and a learning exercise:
