Madhouse said:Also it's worth noting that the format Sky use for storing data on the hard drive hasn't been published (to my knowledge anyway - anyone who can correct me on that and I'll see what I can write). If you replace the drive with a brand new (say 250Gb Maxtor/Quantum) and turn the box on - it just works....
The hard disk internally formats on the fly, and doesn't even have a PC compatible partition or anything. Anyone who knows how to read the video data off one of these disks - and I'll show you how to fit an external caddy to the thing and stream it to a PC!
I have spent hours dumping stuff to a DVD recorder (even though I've got 250Gb internally) and would dearly lve to find an easier way to do it. There is an expansion port in the back of the Sky+ box, and prototypes of a PC interface card were sopposedly in the pipeline but....I never saw one, just heard about them.
It doesn't format 'on the fly', there's an option on the service menu to format the drive - if you don't do that a replacement drive won't work.
All the drives I've tested have been perfectly readable in a PC, it appears to use a standard formatting - just that there doesn't appear to be a PC program that can do anything with the data?.
Madhouse said:Prior to fitting my drive, I read the section on installing an upgraded drive halfway down the page at
http://www.satcure.co.uk/tech/page18.htm
It may be a little out of date now, but I'm just quoting what I read prior to installing my drive, bought brand new from eBuyer. Must have just been a fluke that I didn't need to format it. You do need to perform a "full system reset", but on my box (Pace V1), that took about three minutes - not long enough to format a 250Gb drive. Are you referring to a V2 box (I'll have a look at one tomorrow) or something else.
I'll whip the disk out tomorrow and stick it back in the PC again. It didn't show anything other than an unknown partition type on my machine, but I'll check again.
Encrypted programs are stored in an encrypted form, but according to this the non-encrypted programs are just MPEG2 streams. Macrovision is generally straightforward to remove,depending on the version, but not the Videoguard encryption. But anyway, the file/directory structure isn't PC compatible as such.
