A motor that starts will full load should ideally be ramped up in place of applying full power, zero rpm is the point the motor is drawing maximum current when full voltage is applied.
Max.
Max.
That is why I phrased the question as I did. It is a 3A motor but likely draws more at start up or maximum load or if it got jammed up.A motor that starts will full load should ideally be ramped up in place of applying full power, zero rpm is the point the motor is drawing maximum current when full voltage is applied.
Max.
Thanks, there’s a 10A on the way arriving Thursday. I’m sure it will be exhausted from the “long journey” but will hopefully still cover my needs.If the proposed controller is from the orient it's probably rated in Chinese Amps. For a '3A' motor I'd be looking for a >10A rated controller.
