SMD diode indentification.
fastline
I pulled a whoops and lost a tiny component I desoldered. Luckily I remember the markings and there are others on the board.
The diode is an SOT-23 package with two identically oriented diodes. The markings were "A4" then a sideways 7 next to that. Not sure what to make of the seven but when I look up an A4 diode, there is some indication it is a schottky, some not.
The diode only functions as a reverse polarity device to protect a driver chip ground. It is in series between ground and the chip, and there is also a parallel 10k resistor. IMO, does not seem like a schottky is needed there.
I am simply going to have to buy another and move on but need to make sure I get something appropriate.
This could be it.
https://www.digikey.com/product-detail/en/BAV70W,115/568-6031-1-ND/2531318?WT.srch=1
I have not seen any explanation for the marking of a sideways 7, so I am just trying to determine if there is any significance there?
No idea. Date code perhaps?
From a little more checking around, I do think the 7 is a lot code.
Your welcome.
Well I hope you get it sorted out.
