Speakerguy
Active Member
Hey guys,
This is a somewhat technical power electronics question. I'm designing the LC output filter for a PWM audio amplifier. I'm trying to pick an appropriate inductor. I'm looking for at least 100W output into any load (4 or 8 ohm nominal). The device I'm using is the TAS5261 output stage with the TAS5518C modulator from TI.
Switching frequency is 384KHz. Voltage is (up to) 50V for an H-bridge into the load (BTL bridge tied load). I am looking at the DR127 series inductors from Digikey since they are easily available.
Digi-Key - 513-1037-1-ND (Coiltronics/Div of Cooper/Bussmann - DR127-100-R)
I am not sure if it is suitable however. Could someone show/explain/give me a link to help me understand how to properly derate an inductor in this application?
Also, does anyone know if this style inductor is as well shielded as a good toroid? Is it significantly better? Any help in the EMI area as far as inductor construction is appreciated too.
Thanks!
Thanks!
