With a diode you only need a 15 volt transistor. With 4X resistor you need a 60V transistor. (assuming you are driving a relay with a transistor)However, it begs the question, why use a diode at all? Wouldn't a resistor that is 4 times the relay coil resistance do the job better?
Assuming the stray capacitance is high enough so the the inductive energy doesn't push the voltage higher than that.It was just a quizzical question. I guess you could dispense with diode or resistor and just use a 2,000V transistor.
