rjvh said:make sure your valves are also SS
also your pipe should be thick enough to withstand pressures up to 12 bar (175 PSI)
Unlike Ammonia, a Lithium systems runs in a vacuum.
bryan1 said:Nigle's quote of 'it's just not viable' is a typical response from a city slicker who only needs to turn a knob on their aircon for cooling.
rjvh said:and how much is your underpressure??
vacuum is just negative pressure
rjvh said:why do we use amonia chloride solution ?
this is only because it is capable of holding a good value of energie
Pommie said:Ammonia systems do work in real time.
crashsite said:Using ammonia as the working fluid in a refrigerator does work in real time but, the ammonia chloride system (that was referenced and was described in a link from an earlier post) cycles, with the cooling being done in off-sunlit hours. Sorry, I probably didn't put in enough, or the right, parts of the quote to clarify.
rjvh said:england what about a sollar water heater for your hot water supply![]()
the problem with england is the same as holland (where i am orriginaly from) lack of sun hours
Pommie said:There is no Ammonia Chloride system.
All systems cycle.
All systems can be made to work in real time. They just get a bit more complex.
rjvh said:i am familiar with your reference article
but this article is published a few years ago and this guy is from canada
plenty of calsium chloride there but in cambodia it's not that easy to obtain
i bet in brisbain it's also not a common good that you buy on every street corner
amonia is again a different story
in a country with some industry it will be availible but after 9/11 people ask a lot more questions what you gona do with it
it's still nasty stuf which you can use in manny nasty ways
rjvh said:you've ever been in cambodia ???
the outback in australia is better stocked then here
