I've seen a post here regarding dual PIRs for stair lighting but I'm wondering if anyone can help with how to wire up dual PIRs for stairs where the lighting is LED and the power is from a small solar panel. I'm actually surprised there isn't something I can buy off the shelf. I wondered if I purchased two such units from Maplin would I be able to wire them up in such a way so as to have the lights activated from either top of the stairs or bottom of the stairs.
I don't need flood lighting - just enough to see each stair so you don't have an accident. Previously (before I was thinking of solar) I had already bought some strip LED lighting which came with a transformer - I was hoping to fit them flush into the side of the stairway. Later for an entirely different purpose I had also purchased a PIR flood light unit from maplin for the front door porch. (images attached) Not having time to fit either, I considered the idea of using the solar power from the flood lights to power the LED strip lights for the stairs. But was stopped short when I realised I would need two PIRs not one.
So to be clear. I would be using the solar panel and PIR from the floodlights (But not the lights), adding another PIR and using the strip lights for the stairs, to end up with strip lighting on the stairs, powered from a solar powered charged source, and triggered from either the upstairs PIR or the downstairs PIR.
I have some experience with electronics in the past but confess to being a little rusty and not up to speed with regarding wiring two separate PIRs to the same circuit.
Not sure if these links to the images on my dropbox will work but here goes - here is a link to a folder with three images
https://www.dropbox.com/sh/lhg7uhlsuak6rm7/AAC7ViWe3Rpt8BCDavfBJVGga?dl=0
