Most people can not board swap.New non CRT are made for board swapping. No skills required really.
Nothing wrong with swapping whole boards if its a viable option. Sometimes its more cost/time effective to do so and you can always go back and dig the scrap board out later if you have time for it. I definitely prefer having the options of repair or replace at my disposal.
There are no schematics in my field so I am used to working in the darkIt's nice to have the option, but now it's common practice for manufacturers to not even make the circuit diagrams available, so you're working very much in the dark.
Essentially you do warranty repairs now, and once it's out of warranty throw it away and buy a new one.
As a Sony service agent I replaced MANY LCD panels over the years (it's by FAR the most common failure on a decent make LCD TV), and sometimes I even replaced them out of warranty, as some Sony LCD panels were quite reasonably priced. However,since a few years ago they no longer supply LCD panels, either in or out of warranty - instead they supply an exchange TV (either the same model, or a later similar spec model) if the LCD fails - it's called AES (Advanced Exchange Scheme). Under warranty it's obviously free to the customer, but out of warranty it's a 'special' price - so 'special' that it's more than the original cost of the TV was.
So again, once out of warranty, throw it away.
The manual solder suckers I used to get seamed like they were only good for a few projects before falling apart or maybe I was just getting poor quality ones.
My exact one (or two, one at home and one at work) - I tell a lie - three, two at work, one in a draw, and one in my overall pocket.You are definitely getting poor quality ones!
I think this one is now over 30 years old and still in regular use - though it has had an occasional new nozzle..
Seems tv's never hold up that well. I could see someone doing pretty good for themselves as a mobile TV repair man. Schematics or not.
A solder sucker is a tool that removes melted solder from a circuit when things go wrong or you want to change a component.Hi! What is a solder sucker?
Ive got three 'suckers' not one is any good..Trigger stiff, piston not fitting nozzle , top jumps out.. and more...
i worked at a major retailer's service center for 9 years. they sell a TV for less than what they would charge for any one of the 3 parts (panel, main pcb, and power supply). when the warranty expires, they expect you to buy a new one. most manufacturers of "smart" devices only provide firmware upgrades for a limited time. panasonic is the worst with that one, they cut off firmware updates almost as soon as the warranty period is over. other manufacturers like samsung and lg seem to provide firmware updates up to about 1.5-2 years after the warranty expires. as far as pricing repair parts out of reach, panasonic again is the worst. for a blu-ray player that costs $200 in the store, the replacement cost of the power supply is $250, the drive is $600, and the main board is $400.But cost is the main factor - "Yes Mrs. Smith, we've repaired your £500 TV for you, that will be £728.64, thank you"![]()
