int dataPin = 2; // ic: 14, ser_in Define which pins will be used for the Shift Register control
int latchPin = 3; // ic:12 silkscreen numbers!
int clockPin = 4;
char displayPointer=0; // for interrupt use...
static uint8_t font [80] = //numbers stored here
0x00, 0x7c, 0xa2, 0x92, 0x8a, 0x7c, 0x00, 0x00, // 0
0x00, 0x42, 0xfe, 0x02, 0x00, 0x00, 0x00, 0x00, // 1
0x00, 0x42, 0x86, 0x8a, 0x92, 0x62, 0x00, 0x00, // 2
0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 3
0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 4
0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 5
0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 6
0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 7
0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 8
0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 9
unsigned char buffer[32]; // buffer for screen
unsigned char backbuffer[32]; // Spare screen for drawing on
char power[8]={128,64,32,16,8,4,2,1};
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine
for (int i = 0; i < 8; i++)
PORTD = B00000000; //turn latch low
shiftOut(dataPin, clockPin, MSBFIRST, 1 << i); //Send the data #2 (what columns to power)
shiftOut(dataPin, clockPin, LSBFIRST, font[i + 8]); //Send the data #1 ( what data to draw)
PORTD = B00001000;
if(displayPointer == 0 ) // 1st frame..
PORTB = buffer[displayPointer]; // Move buffer row by row( 4 row sections per row )
if(++displayPointer==32) // 32 LED row sections in total
displayPointer = 0; // Back to first row..*/
void pixel(signed char x,signed char y,int cond)
int tmp;
char pix,msk;
if(x<0 || y<0) return; // outside drawing limits negative
if(x>31 || y>7) return; // outside drawing limits positive
tmp = (y << 2) + (x>>3); // Linear position
pix = x%8; // pixel required
pix = power[pix];
msk = backbuffer[tmp]; // get exsisting data
if(cond == 2)
pix ^= msk; // XOR data to screen
if (cond == 1)
pix = ~pix;
pix &= msk; // AND data to screen
if(cond == 0)
pix |= msk; // OR data to screen
backbuffer[tmp] = pix; // apply changes
void charput(char ch, signed char x,signed char y)
signed char x1, y1;
const uint8_t* addr2; // pointer to character
char disp;
ch -= 0x20; // characters starts a 0 not 0x20
addr2 = &font[0]; // start of font array
addr2 = addr2 + ((int)ch * 8); // start place in font array
for( y1=0;y1<8;y1++) // eight rows
disp = *addr2;
for (x1 = 0; x1<8; x1++) // eight pixels
if(disp & power[x1])
pixel(x+x1,y+y1,0); // OR the pixel to the display buffer
addr2++;
void strput(const char* ch, signed char x,signed char y)
int addr;
while (*ch )
charput(*ch++,x,y); // write a string to the display buffer
x+=7;
void clr() //clear
int addr;
for(addr=0;addr<32;addr++) // Empty display buffer
backbuffer[addr]= 0;
void Blit() //transfers data between display buffer to screen buffer
int addr=0;
noInterrupts(); // disable all interrupts during setup
for(addr=0;addr < 32;addr ++)
buffer[addr] = backbuffer[addr]; // put all data from display buffer
} // to screen buffer
interrupts(); // enable all interrupts
void displaystring(void) // this routine prints through the screen buffer
{ // moving one pixel at a time
signed char x=32,y=0; // I made these signed so I could print
for(y = 0;y < 96 ;y++) // to nowhere so I could produce the scrolling effect
clr(); // Clear the display buffer
strput("HELLO WORLD!!",x--,0); // adjust the scrolling string
Blit(); // pass to screen buffer
delay(80); // time to view
void setup() //setup runs once
DDRD = DDRD | B11111100; //port registers used to set pin directions
//int sx,sy; //these two necessary? couldn't see them anywhere else than ball-thingy
//int xdir=1, ydir=1;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 31250; // compare match register 16MHz/256/2Hz
TCCR1B |= (1 << WGM12); // CTC mode, free-running, clear on match
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
displaystring(); //prints just hello world at startup
while(1) //essentially loop()? but loop is still needed...
clr(); //clear buffer first
/*sx += xdir; sy += ydir; no balls needed so can be omitted
strput("]",sx,sy); // this is a ball character for bouncing routine
if(sx>27) xdir = -1; /// Wall limits
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
if(sy<0) ydir = 1;*/
delay(80); //delay, but won't effect ISR
Blit(); //swap buffers
} // End main
void loop() //just sitting here
i think you are referring to the blit function, so what happens is you write what you want to display in the backbuffer, when you are done editing you call the blit function where it takes the info from backbuffer and passes it to buffer, then when the isr is called it displays all info in buffer. Blit is like the apply button , so the micro displays with proper timing, but giving you the extra time needed to populate your data.(Ian mentioned about it earlier about keeping leds alive?)
int clockPin = 4;
static char font [80] = //numbers stored here
unsigned char columndata;
unsigned char columnnumber;
if(TIFR2) // Make sure its the timer interrupt.
columndata= buffer[displayPointer]; // 32 bits of column
columnnumber = displayPointer;
setcolumn(columnnumber);
setdata(columndata);
storeclock();
if(++displayPointer==32) { displayPointer = 0; } // 32 LED row sections in total
TIFR2 = 0; // Clear timer 2 interrupt flag
void setcolumn(unsigned char col){
unsigned char pos;
for (pos = 0;pos<32;pos++){
if (col == pos){digitalWrite(dataPin ,HIGH);}else {digitalWrite(dataPin ,LOW);} // replace PIN1 with DATA pin
shiftclock();
void setdata(unsigned char dat){
unsigned char pos;
for (pos = 0;pos<8;pos++){
if (dat & 128){dat-=128;digitalWrite(dataPin ,HIGH);}else { digitalWrite(dataPin ,LOW);} // Replace PIN1 with DATA pin
dat = dat * 2;
shiftclock();
void shiftclock(void){
digitalWrite(clockPin ,HIGH);digitalWrite(clockPin ,LOW);// change PIN2 to SHIFTCLOCK pin, add delay if this is too fast for shift registers
void storeclock(void){
digitalWrite(latchPin ,HIGH);digitalWrite(latchPin , LOW ); // change PIN3 to STORECLOCK, add delay if this is too fast for shift registers
int tmp;
char pix,msk;
pix = power[pix];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
const char* addr2; // pointer to character
char disp;
disp = *addr2;
addr2++;
int addr;
while (*ch )
x+=7;
void clr() //clear
int addr;
int addr=0;
delay(1000); // time to view
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
} // End main
int clockPin = 4;
storeclock();
unsigned char pos;
shiftclock();
unsigned char pos;
dat = dat * 2;
shiftclock();
int tmp;
char pix,msk;
pix = power[pix];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
char disp;
disp = *addr2;
addr2++;
int addr;
while (*ch )
x+=7;
void clr() //clear
int addr;
int addr=0;
for(y = 0;y < 32 ;y++) // to nowhere so I could produce the scrolling effect
backbuffer[y] = y/4 + 1;
delay(500); // time to view
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
} // End main
Indeed, there is living on matrixlooks good, somehow
presactly!Indeed, there is living on matrix![]()
int clockPin = 4;
storeclock();
if(--displayPointer==0) { displayPointer = 32; } // 32 LED row sections in total
unsigned char pos;
shiftclock();
unsigned char pos;
dat = dat * 2;
shiftclock();
digitalWrite(latchPin ,HIGH);digitalWrite(latchPin , LOW ); // change PIN3 to STORECOCK, add delay if this is too fast for shift registers
int tmp;
char pix,msk;
pix = power[pix];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
char disp;
disp = *addr2;
addr2++;
int addr;
while (*ch )
x+=7;
void clr() //clear
int addr;
int addr=0;
void displaystring2(void) // this routine prints through the screen buffer
pixel(1,1,0);
pixel(2,2,0);
pixel(32,8,0);
pixel(31,8,0);
void displaystring3(void) // this routine prints through the screen buffer
charput("H", 1,1)
charput("I", 12,12)
void displaystring4(void) // this routine prints through the screen buffer
strput("WOOF",0,0); // adjust the scrolling string
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
displaystring2(); //prints just hello world at startup
displaystring3(); //prints just hello world at startup
displaystring4(); //prints just hello world at startup
if(sy>4) ydir = -1;
if(sx<0) xdir = 1;
} // End main
