(Solved)Again problem with matrix, this time 8x32
Sorry for delay, got OLED screens and couple LCD's too, played with them and managed to place RTC clock to 0.96" OLED hehe...
But,as for this subject, errors popped out. I haven't yet touched RTC library for this project.
C:
Arduino: 1.6.7 (Windows 7), TD: 1.27, Board: "Arduino Pro or Pro Mini, ATmega328 (5V, 16 MHz)"
C:\Users\Atte\AppData\Local\Temp\arduino_6d4799411362b184c1851ba8af345ff2\sketch_jan21a.ino: In function 'void setTime()':
sketch_jan21a:55: error: 'months' was not declared in this scope
 Serial.println(months[month-1]);
sketch_jan21a:62: error: 'days' was not declared in this scope
 Serial.println(days[weekday-1]);
exit status 1
Invalid library found in C:\Users\Atte\Documents\Arduino\libraries\Ardumoto: C:\Users\Atte\Documents\Arduino\libraries\Ardumoto
Invalid library found in C:\Users\Atte\Documents\Arduino\libraries\Bluetooth: C:\Users\Atte\Documents\Arduino\libraries\Bluetooth
Invalid library found in C:\Users\Atte\Documents\Arduino\libraries\OBD-II_UART: C:\Users\Atte\Documents\Arduino\libraries\OBD-II_UART
Invalid library found in C:\Users\Atte\Documents\Arduino\libraries\reorder_table_creator: C:\Users\Atte\Documents\Arduino\libraries\reorder_table_creator
Invalid library found in C:\Users\Atte\Documents\Arduino\libraries\Serial7SegmentDisplay: C:\Users\Atte\Documents\Arduino\libraries\Serial7SegmentDisplay
Invalid library found in C:\Users\Atte\Documents\Arduino\libraries\sevenseg: C:\Users\Atte\Documents\Arduino\libraries\sevenseg
  This report would have more information with
  "Show verbose output during compilation"
  enabled in File > Preferences.
Hmm, when entering serial mode, all leds are lit and says only "Th" trying to say thank you?
ya, or Thursday, but i deleted both of those, could be cause of our clock settings, serial port may have bad timing, lets try to cut programming time/serial functions completely
#include <Wire.h>
#include "FontMap.h"
int dataPin = 2; // ic: 14, ser_in Define which pins will be used for the Shift Register control
int latchPin = 3; // ic:12 silkscreen numbers!
int clockPin = 4;
const int DS1307 = 0x68; // Address of DS1307 see data sheets
// Initializes all values:
byte second = 1;
byte minute = 1;
byte hour = 1;
byte weekday = 0;
byte monthday = 0;
byte month = 0;
byte year = 0;
unsigned char displayPointer=0; // for interrupt use...
unsigned char buffer1[32]; // buffer for screen
unsigned char backbuffer[32]; // Spare screen for drawing on
unsigned char power[8]={128,64,32,16,8,4,2,1};
ISR(TIMER1_COMPA_vect) // timer compare interrupt service routine
if(TIFR2) // Make sure its the timer interrupt.
setcolumn(displayPointer);
setdata(buffer1[displayPointer]);
digitalWrite(latchPin ,HIGH);digitalWrite(latchPin , LOW ); // STORECLOCK
if(++displayPointer==32) { displayPointer = 0; } // 32 LED row sections in total
TIFR2 = 0; // Clear timer 2 interrupt flag
byte decToBcd(byte val) {
return ((val/10*16) + (val%10));
byte bcdToDec(byte val) {
return ((val/16*10) + (val%16));
// This set of codes is allows input of data
void setTime() {
Serial.print("Please enter the current year, 00-99. - ");
year = readByte();
Serial.println(year);
Serial.print("Please enter the current month, 1-12. - ");
month = readByte();
Serial.println(month);
Serial.print("Please enter the current day of the month, 1-31. - ");
monthday = readByte();
Serial.println(monthday);
Serial.println("Please enter the current day of the week, 1-7.");
Serial.print("1 Sun | 2 Mon | 3 Tues | 4 Weds | 5 Thu | 6 Fri | 7 Sat - ");
weekday = readByte();
Serial.println(weekday]);
Serial.print("Please enter the current hour in 24hr format, 0-23. - ");
hour = readByte();
Serial.println(hour);
Serial.print("Please enter the current minute, 0-59. - ");
minute = readByte();
Serial.println(minute);
second = 0;
Serial.println("The data has been entered.");
// The following codes transmits the data to the RTC
Wire.beginTransmission(DS1307);
Wire.write(byte(0));
Wire.write(decToBcd(second));
Wire.write(decToBcd(minute));
Wire.write(decToBcd(hour));
Wire.write(decToBcd(weekday));
Wire.write(decToBcd(monthday));
Wire.write(decToBcd(month));
Wire.write(decToBcd(year));
Wire.endTransmission();
// Ends transmission of data
byte readByte() {
while (!Serial.available()) delay(10);
byte reading = 0;
byte incomingByte = Serial.read();
while (incomingByte != '\n') {
if (incomingByte >= '0' && incomingByte <= '9')
reading = reading * 10 + (incomingByte - '0');
else;
Serial.flush();
return reading;
void printTime() {
char buffer[3];
const char* AMPM = 0;
readTime();
Serial.print(weekday);
Serial.print(" ");
Serial.print(month);
Serial.print(" ");
Serial.print(monthday);
Serial.print(", 20");
Serial.print(year);
Serial.print(" ");
if (hour > 12) {
hour -= 12;
AMPM = " PM";
else AMPM = " AM";
Serial.print(hour);
Serial.print(":");
sprintf(buffer, "%02d", minute);
Serial.print(buffer);
Serial.println(AMPM);
void readTime() {
Wire.requestFrom(DS1307, 7);
second = bcdToDec(Wire.read());
minute = bcdToDec(Wire.read());
hour = bcdToDec(Wire.read());
weekday = bcdToDec(Wire.read());
monthday = bcdToDec(Wire.read());
month = bcdToDec(Wire.read());
year = bcdToDec(Wire.read());
void setcolumn(unsigned char col){
signed char pos;
for (pos = 32;pos>-1;pos--){
if (col == pos){digitalWrite(dataPin ,HIGH);}else {digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
digitalWrite(clockPin ,HIGH);digitalWrite(clockPin ,LOW);
void setdata(unsigned char dat){
unsigned char pos;
for (pos = 0;pos<8;pos++){
if (dat & 128){dat-=128;digitalWrite(dataPin ,HIGH);}else { digitalWrite(dataPin ,LOW);} // PIN1 DATA pin
dat = dat * 2;
void clr() //clear
int addr;
for(addr=0;addr<32;addr++) // Empty display buffer
backbuffer[addr]= 0;
void Blit() //transfers data between display buffer to screen buffer
int addr=0;
noInterrupts(); // disable all interrupts during setup
for(addr=0;addr < 32;addr ++)
buffer1[addr] = backbuffer[addr]; // put all data from display buffer
} // to screen buffer
interrupts(); // enable all interrupts
void pixel(signed char x,signed char y,int cond)
unsigned char pix,msk;
if(x<0 || y<0) return; // outside drawing limits negative
if(x>31 || y>7) return; // outside drawing limits positive
pix = power[y];
msk = backbuffer[x]; // get exsisting data
if(cond == 2)
pix ^= msk; // XOR data to screen
if (cond == 1)
pix = ~pix;
pix &= msk; // AND data to screen
if(cond == 0)
pix |= msk; // OR data to screen
backbuffer[x] = pix; // apply changes
void charput(unsigned char ch, signed char x,signed char y)
signed char x1, y1;
unsigned char disp;
unsigned char disp2;
for( x1=0;x1<8;x1++) // eight rows
disp = font[x1+(ch * 8)];
for (y1 = 0; y1<8; y1++) // eight pixels
disp2 = disp & power[y1];
if(disp2 > 0)
pixel(x+x1,y+y1,0); // OR the pixel to the display buffer
void strput(const char* ch, signed char x,signed char y)
int addr;
while (*ch )
charput(*ch++,x,y); // write a string to the display buffer
x+=7;
unsigned char Vscroll(unsigned char value,unsigned char valueOL, signed char x,signed char y, unsigned char cntr1){ // Vscroll(hour, hourLA, x,y,scrollctrHR);}
charput((valueOL/10),x,(y + cntr1 - 8));
charput((valueOL%10),x+8,(y + cntr1 - 8));
charput((value/10),x,(y + cntr1 ));
charput((value%10),x+8,(y + cntr1 ));
if (cntr1 > 0){cntr1--;}
return cntr1;
void setup() //setup runs once
signed char cntr;
DDRD = DDRD | B11111100; //port registers used to set pin directions
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
OCR1A = 5; // compare match register 16MHz/256/2Hz -----------------------------------> delay time (lcd flicker/brightness)
TCCR1B |= (1 << WGM12); // CTC mode, free-running, clear on match
TCCR1B |= (1 << CS12); // 256 prescaler
TIMSK1 |= (1 << OCIE1A); // enable timer compare interrupt
Wire.begin();
delay(2000); // This delay allows the MCU to read the current date and time.
} // End main
void loop() //just sitting here
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
unsigned char RTCsim = 16;
unsigned char scrollctrHR= 0;
unsigned char scrollctrMN = 0;
unsigned char scrollctrSE = 0;
clr();
charput(58,0,0);
charput(58,2,0);
Blit();
delay(300);
readTime();
if (second != secondBK){secondLA = secondBK; secondBK=second;scrollctrSE=8;} else {charput((second/10),3,0);charput((second%10),11,0);}
if (scrollctrSE > 0){scrollctrSE = Vscroll(second, secondLA, 3,0,scrollctrSE);}
if (minute != minuteBK ){minuteLA = minuteBK; minuteBK =minute;scrollctrMN=8;} else {charput((minute/10),19,0);charput((minute%10),27,0);}
if (scrollctrMN > 0){scrollctrMN = Vscroll(minute, minuteLA, 19,0,scrollctrMN);}
//if (hour != hourBK ){hourLA = hourBK; hourBK =hour;scrollctrHR=8;} else {charput((hour/10),x,0);charput((hour%10),x,0);}
//if (scrollctrHR > 0){scrollctrHR = Vscroll(hour, hourLA, x,0,scrollctrHR);}
Blit();
delay(300);
if (RTCsim != 0){RTCsim --;}else {
RTCsim =16;
if (second <60){second++;}else{second = 0;}
hehe, now screen and serial are both blank
...maybe not!
#include <Wire.h>
int clockPin = 4;
byte second = 1;
byte minute = 1;
byte hour = 1;
byte weekday = 0;
byte monthday = 0;
byte month = 0;
byte year = 0;
void setTime() {
year = readByte();
month = readByte();
hour = readByte();
second = 0;
byte readByte() {
byte reading = 0;
else;
Serial.flush();
return reading;
void printTime() {
char buffer[3];
readTime();
Serial.print(" ");
Serial.print(" ");
Serial.print(year);
Serial.print(" ");
if (hour > 12) {
hour -= 12;
AMPM = " PM";
else AMPM = " AM";
Serial.print(hour);
Serial.print(":");
void readTime() {
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
unsigned char disp;
if(disp2 > 0)
int addr;
while (*ch )
x+=7;
return cntr1;
signed char cntr;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
clr();
charput(58,0,0);
charput(58,2,0);
Blit();
delay(300);
//if (minute != minuteBK ){minuteLA = minuteBK; minuteBK =minute;scrollctrMN=8;} else {charput((minute/10),19,0);charput((minute%10),27,0);}
//if (scrollctrMN > 0){scrollctrMN = Vscroll(minute, minuteLA, 19,0,scrollctrMN);}
Blit();
delay(300);
Serial is empty, but every now and then couple zeroes pop to quite middle of matrix
I cut out serial port for now, lets double check to see if scroll still works
#include <Wire.h>
int clockPin = 4;
byte second = 1;
byte minute = 1;
byte hour = 1;
byte weekday = 0;
byte monthday = 0;
byte month = 0;
byte year = 0;
void setTime() {
year = readByte();
month = readByte();
hour = readByte();
second = 0;
byte readByte() {
byte reading = 0;
else;
Serial.flush();
return reading;
void printTime() {
char buffer[3];
readTime();
Serial.print(" ");
Serial.print(" ");
Serial.print(year);
Serial.print(" ");
if (hour > 12) {
hour -= 12;
AMPM = " PM";
else AMPM = " AM";
Serial.print(hour);
Serial.print(":");
void readTime() {
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
unsigned char disp;
if(disp2 > 0)
int addr;
while (*ch )
x+=7;
return cntr1;
signed char cntr;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
unsigned char virtual_timer = 10;
while (1){
clr();
charput(58,-3,0);
charput(58,-1,0);
if (scrollctrSE > 0){scrollctrSE = Vscroll(second, secondLA, 3,0,scrollctrSE);} else {charput((second/10),3,0);charput((second%10),11,0);}
//if (scrollctrMN > 0){scrollctrMN = Vscroll(minute, minuteLA, 19,0,scrollctrMN);} else {charput((minute/10),19,0);charput((minute%10),27,0);}
//if (scrollctrHR > 0){scrollctrHR = Vscroll(hour, hourLA, x,0,scrollctrHR);} else {charput((hour/10),x,0);charput((hour%10),x,0);}
Blit();
delay(300);
if (virtual_timer > 0){virtual_timer--;}else{virtual_timer=10; second++;}
Serial is empty, both of those earlier dots and zeros are now visible , slightly shifted to left.
remember where there were two zeroes? those now scroll, counting up, 00, 01, 02, 03 etc....but very slowly, would take too long video to upload :/ and, serial is empty
doggy, with this I got hours & minutes on screen, only bit flickery, is there any help on this?
C:
//counts from 9999 seconds down
int dataPin = 2;  //IC 14  //Define which pins will be used for the Shift Register control
int latchPin = 3;  //IC 12
int clockPin = 4;  //IC 11
//OE-GND
//MR-VCC
unsigned long previousMillis = 0;  // will store last time LED was updated
const long interval = 1000;  // interval at which to blink (milliseconds)
int del = 10;
int columns = 0;
int counter = 10000;
int m = 1;
  #include <Wire.h>
  #include "RTClib.h"
  RTC_DS1307 RTC;
static uint8_t  numbers [80] =  //numbers stored here
  0x00, 0x7c, 0xa2, 0x92, 0x8a, 0x7c, 0x00, 0x00, // 0
  0x00, 0x42, 0xfe, 0x02, 0x00, 0x00, 0x00, 0x00, // 1
  0x00, 0x42, 0x86, 0x8a, 0x92, 0x62, 0x00, 0x00, // 2
  0x00, 0x84, 0x82, 0xa2, 0xd2, 0x8c, 0x00, 0x00, // 3
  0x00, 0x18, 0x28, 0x48, 0xfe, 0x08, 0x00, 0x00, // 4
  0x00, 0xe4, 0xa2, 0xa2, 0xa2, 0x9c, 0x00, 0x00, // 5
  0x00, 0x3c, 0x52, 0x92, 0x92, 0x0c, 0x00, 0x00, // 6
  0x00, 0x80, 0x8e, 0x90, 0xa0, 0xc0, 0x00, 0x00, // 7
  0x00, 0x6c, 0x92, 0x92, 0x92, 0x6c, 0x00, 0x00, // 8
  0x00, 0x60, 0x92, 0x92, 0x94, 0x78, 0x00, 0x00, // 9
void setup()
  Wire.begin();
  RTC.begin();
  DDRD = DDRD | B00011100;  //set pins as output
void loop()
  DateTime now = RTC.now();
  unsigned long currentMillis = millis();  //take value from millis() each loop
  if (currentMillis - previousMillis >= interval)
  previousMillis = currentMillis;
  if (counter == 0)
  counter = 10000; //reset to start
  else
  counter--;  //if not 0, keep on counting
  columns++; //at each loop run, increment by one
  if (columns > 8)
  columns = 0;  //if counter exceeds 8, reset it
  PORTD = B00000000;  //turn latch low
  shiftOut(dataPin, clockPin, MSBFIRST, 1 << columns);  //Send the data #2  (what columns to power)
  shiftOut(dataPin, clockPin, MSBFIRST, B00000000);  //Send the data #2  (what columns to power)
  pickNumber((now.minute() / m / 1) % 10);  //ones
  PORTD = B00001000;  //turn latch on->show screen
  pickNumber((now.minute() / m / 10) % 10);  //tens
  pickNumber((now.hour() / m / 1) % 10);  //hundreds
  pickNumber((now.hour() / m / 10) % 10);  //thousands
void pickNumber( int count)  //pick numbers from array, at start of whole code
  switch (count)
  case 1: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 8]); break;  //0
  case 2: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 16]); break;  //1
  case 3: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 24]); break;  //2
  case 4: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 32]); break;  //3
  case 5: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 40]); break;  //4
  case 6: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 48]); break;  //5
  case 7: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 56]); break;  //6
  case 8: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 64]); break;  //7
  case 9: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 72]); break;  //8
  case 10: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 80]); break;  //9
  default: shiftOut(dataPin, clockPin, LSBFIRST, numbers[columns + 0]); break;  //9
is that original code? working with RTC library?
adding a delay at the end of main code will help flicker...
also if you add RTC library to my code, will work , all you would need to do is add lines to put second = now.second; or change all the "second" to now.second
Yes, this code is original before ian's , (although he helped with that too!)
Library indeed helped, will try to implement it to your code also! :)
Had to ''repair'' code in my cube, it has LCD screen showing RTC and there wasn't any leading zeroes and placed also date & month as characters (Wednesday, February)
this code is ready for you to include RTC library function, i rem-ed out the minute and hour so we can align the seconds and colons first, i figure you want it to show like this: HH:MM:SS
int clockPin = 4;
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
unsigned char disp;
if(disp2 > 0)
int addr;
while (*ch )
x+=7;
return cntr1;
signed char cntr;
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
//unsigned char virtual_timer = 10;
while (1){
clr();
charput(58,-3,0);
charput(58,-1,0);
second = now.second();
minute = now.minute();
hour = now.hour();
if (scrollctrSE > 0){scrollctrSE = Vscroll(second, secondLA, 14,0,scrollctrSE);} else {charput((second/10),14,0);charput((second%10),23,0);}
Blit();
delay(300);
//if (virtual_timer > 0){virtual_timer--;}else{virtual_timer=10; second++;}
hmm, here i tried to implement RTC, but still get errors
C:
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int clockPin = 4;
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
unsigned char disp;
if(disp2 > 0)
int addr;
while (*ch )
x+=7;
return cntr1;
signed char cntr;
  Wire.begin();
  RTC.begin();
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
while (1){
clr();
charput(58,-3,0);
charput(58,-1,0);
hour = now.hour();
Blit();
delay(300);
C:
C:\Users\Atte\AppData\Local\Temp\arduino_6d4799411362b184c1851ba8af345ff2\sketch_jan21a.ino: In function 'void loop()':
sketch_jan21a:172: error: 'second' was not declared in this scope
 second() = now.second();
sketch_jan21a:172: error: 'now' was not declared in this scope
sketch_jan21a:173: error: 'minute' was not declared in this scope
 minute() = now.minute();
sketch_jan21a:174: error: 'hour' was not declared in this scope
 hour() = now.hour();
exit status 1
oops deleted too much:
if you still get error on second, we may not be able to use it and may need to stick with this screen format: HH:MM
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
unsigned char second, scrollctrHR= 0;
unsigned char minute, scrollctrMN = 0;
unsigned char hour, scrollctrSE = 0;
while (1){
clr();
charput(58,-3,0);
charput(58,-1,0);
hour = now.hour();
Blit();
delay(300);
still getting erros :/?
C:
#include <Wire.h>
#include "RTClib.h"
RTC_DS1307 RTC;
int clockPin = 4;
signed char pos;
unsigned char pos;
dat = dat * 2;
void clr() //clear
int addr;
int addr=0;
pix = power[y];
if(cond == 2)
if (cond == 1)
pix = ~pix;
if(cond == 0)
signed char x1, y1;
unsigned char disp;
if(disp2 > 0)
int addr;
while (*ch )
x+=7;
return cntr1;
signed char cntr;
  Wire.begin();
  RTC.begin();
TCCR1A = 0;
TCCR1B = 0;
TCNT1 = 0;
} // End main
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
while (1){
clr();
charput(58,-3,0);
charput(58,-1,0);
hour = now.hour();
Blit();
delay(300);
C:
sketch_jan21a:168: error: 'now' was not declared in this scope
exit status 1
byte secondBK = 0;
byte minuteBK = 0;
byte hourBK = 0;
byte secondLA = 0;
byte minuteLA = 0;
byte hourLA = 0;
while (1){
hour = now.hour();
clr();
charput(58,-3,0);
charput(58,14,0);
if (scrollctrSE > 0){scrollctrSE = Vscroll(second, secondLA, 15,0,scrollctrSE);} else {charput((second/10),15,0);charput((second%10),23,0);}
Blit();
delay(100);
