Please start your own thread about an AM radio instead of hyjacking this thread about FM transmitters.can smbody send me a low frequency AM receiver?![]()
I am afraid to use my FM transmitter because my FM dial is full of stations. I tested it for only 1 hour after I made it to measure its range.Audioguru I built yours for fun on my protoboard, and it worked suprisingly well (for a rf circuit on proto), well done.
The 3rd transmitter does not have R5 and R6 so don't know which circuit you are talking about.Audio guru ,allow me to ask
if i do not use ur resistor values as u suggest in transmitter #3
but using mine as below, same circuit diagram.,will it works?
You need to learn about electronics to see why certain parts values are used.may i ask how u know the adjustment of the value resistors?
Philips' datasheet for a 2N2222 in a metal package lists its minimum transistion frequency at 250mHz so it will oscillate at 100MHz perfectly.Hi I'm not an expert in electronic but I have a question: In the circuits can I use another transistor than (for example) the 2N2222?
I have some more transmitters (FM) for you to view...
The 4.7pF capacitor provides positive feedback from collector to emitter so that the transistor oscillates near 100MHz on the FM broadcast band.Regarding the second transmitter, it looks the designer here is using a 4.7 pF feedback to the collector, is that feedback needed to maintain the gain or for some other reasons?
No.The 0.01 UF seems it will short at certain frequencies and therefore block all those frequencies from being coming out to the antenna. Am I getting this right?.
The LC circuit, stray capacitance in parallel with it including anything conductive near the antenna, the capacitance of the transistor (also affected by voltage), the value of the positive feedback capacitor and the stray capacitance in parallel with them determine the frequency.how did you figure out the frequency of the transmitter to be 100 Mhz, is that from the LC circuit?
Of course adding an RF amplifier will increase the range.If you want to increase the range can you just another another amplfying stage?
The tracking transmitters are on another thread.Thanks for the reply, did you have a look at the tracking transmitter I believe was posted by Colin? does the antenna on the circuit picks up signal, which turns on the LED?
No.The microphones of the circuit 1 and 3 should be in series with a resistor of 4.7K~10K as the #2 circuit is.
