daemian said:Hi ppl,
I was thinking of using a sonar and sound sensor on a vehicle.The main problem is that since there is a lot of noise from the engine the sound sensor can't trace the sonar signal back again.Is there any way to make this noise signal more traceable?
:shock:You would normally use ultrasonic transducers for sonar on a vehicle, along with sharply tuned amplifier stages - this would reduce any engine noise.
daemian said:Thanks electronic god for the answer.I thought that ultrasonic transducer is proper for a distance of 20 meters long maximum.Could you please give more details about what ultrasonic transducers should i use(or where can i find them) and how could i implement sharply tuned amplifier stages(i am just a newbie but i have to know
I believe they use ultrasonics, instead because it is of higher frequency, therefore blocking the engine noise because it has a much lower frequncy.
The band pass filter allows the ultrasonic signals to pass but the lower frequency (engine noise) to be blocked.
daemian said:Do i have to construct the band pass filter by myself or it is already build in the sonar?Also what is the top speed of a vehicle in order the sonar to be useful?
