There is some laws against electrical work but they're not that strictly enforced the way gas is.
I think the law in the US is sill, untrained people shouldn't be allowed to work with gas which is obviously much more dangerous than electricity.
I do know the explosive force of one cubic foot (1 cubic foot = 0.0283168466 cubic meters) in a simple enclosed box is ugly.
Oh, I forgot to warn you that the switch, resistor and capacitor both need to have a maximum voltage rating of at least 400V and the diode needs to be rated to at least 750V because of the voltage doubler effect.
The peak voltage of a 230VAC sine wave is 325V.I was just wondering. When you say 400v it is because you cant get anything at 230v right? it goes from 200v to 400v atleast when we talk diodes. (and I do use a 1kv diode )
312V is no where near high enough to make a spark, as a general rule you need 1.1kV per mm.Hmm all these high voltage komponents. For making a spark I could just use the automotive ignition coil add 12v and get a suitable 312v out to make the spark? And then I dont need these high voltage komponents? Thats only for making big sparks.
312v should be good enough, and I will be able to use a small 16v capacitor and normal resistor and 4001 diode right?
