Tallon Karde
I have successfully built the first part of this circuit on a test board. I cut off before the 1k/transistor junction to isolate the basic part of this circuit. I found that I cannot use the latching SCRs at the top of the circuit as written in by KINARFI as they will not conduct with the amount of resistance in the circuit, and there is no way that I can see to make them work. I resorted back to the latching relay in the original schematic.
I discovered the circuit worked as planned after working out a bug that I created. I also found that by varying the amount of resistance on R1 and R6, I can change the length of time that each circuit will wait before energizing the motor relays. Now if I can just find a reliable soldering iron that I can use to put everything together.
