speeding up the SPI CLOCK
irilias
Hi, i hope you're all doing well .
i'm trying to implement an interface between a PIC16f877a (8Mhz xtal) and an MMC, and i have a bit of a problem with CCS, now i understand that MMC requires a clock lower than 400khz for initialization and that's what i did, the code is running with SPI_CLK_DIV_64 (125khz).
my question is, what code should i add to speed up the SPI connection? i mean should i just redefine the SPI setup: Setup_spi(SPI_CLK_DIV_4) ?!
my second question concerns the bus interface circuitry, what Transistors do you recommend using ?
#include<16f877a.h>
#fuses hs,nowdt, noprotect, nolvp
#use delay(clock=10000000)
#include<math.h>
#include<string.h>
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7)
int mmc_init();
int mmc_response(unsigned char response);
int mmc_write_block(unsigned long block_number);
/************************** MMC Init **************************************/
/* Initialises the MMC into SPI mode and sets block size, returns 0 on success */
int mmc_init()
int i;
SETUP_SPI(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_64);
*0x94 |= 0x40;		// set CKE = 1 - clock idle low
*0x14 &= 0xEF; 		// set CKP = 0 - data valid on rising edge
OUTPUT_HIGH(PIN_C2); 	// set SS = 1 (off)
for(i=0;i<10;i++)  	// initialise the MMC card into SPI mode by sending clks on
SPI_WRITE(0xFF);
OUTPUT_LOW(PIN_C2);  // set SS = 0 (on) tells card to go to spi mode when it receives reset
SPI_WRITE(0x40);	 // send reset command
SPI_WRITE(0x00);	 // all the arguments are 0x00 for the reset command
SPI_WRITE(0x00);
SPI_WRITE(0x00);
SPI_WRITE(0x00);
SPI_WRITE(0x95);	 // precalculated checksum as we are still in MMC mode
puts("Sent go to SPI\n\r");
if(mmc_response(0x01)==1) return 1
// if = 1 then there was a timeout waiting for 0x01 from the mmc
puts("Got response from MMC\n\r");
i = 0;
while((i < 255) && (mmc_response(0x00)==1))  // must keep sending command if response
SPI_WRITE(0x41);     // send mmc command one to bring out of idle state
SPI_WRITE(0x00);    // all the arguments are 0x00 for command one
SPI_WRITE(0x00);
SPI_WRITE(0x00);
SPI_WRITE(0x00);
SPI_WRITE(0xFF);   // checksum is no longer required but we always send 0xFF
i++;
if(i >= 254) return 1;  // if >= 254 then there was a timeout waiting for 0x00 from the mmc
puts("Got out of idle response from MMC\n\r");
SPI_WRITE(0xFF);   // extra clocks to allow mmc to finish off what it is doing
SPI_WRITE(0x50);    // send mmc command one to bring out of idle state
SPI_WRITE(0x00);
SPI_WRITE(0x00);
SPI_WRITE(0x02);   // high block length bits - 512 bytes
SPI_WRITE(0x00);  // low block length bits
if((mmc_response(0x00))==1) return 1;
puts("Got set block length response from MMC\n\r");
return 0;
/************************** MMC Write Block  *******************************/
unsigned long i;
unsigned long varh,varl;
char p,f,n;
set_adc_channel(0);
delay_us(10);
f=read_adc();
n=(f*5)/256;
p=(n*9375)/206;
varl=((block_number&0x003F)<<9);
varh=((block_number&0xFFC0)>>7);
puts("Write block\n\r");   // block size has been set in mmc_init()
SPI_WRITE(0x58);   // send mmc write block
SPI_WRITE(varh);
SPI_WRITE(varl);
SPI_WRITE(0x00);  // always zero as mulitples of 512
puts("Got response to write block\n\r");
SPI_WRITE(0xFE);   // send data token
for(i=0;i<512;i++)
SPI_WRITE(p);   // send data
SPI_WRITE(0xFF);   // dummy CRC
SPI_WRITE(0xFF);
if((SPI_READ(0xFF)&0x0F)!=0x05) return 1;
puts("Got data response to write block\n\r");
return 0;
/************************** MMC get response  *******************************/
/**** Repeatedly reads the MMC until we get the response we want or timeout ****/
unsigned long count = 0xFFFF;
  // 16bit repeat, it may be possible to shrink this to 8 bit but there is not much point
while(SPI_READ(0xFF) != response && --count > 0);
if(count==0) return 1;  // loop was exited due to timeout
else return 0;	 // loop was exited before timeout
Thank you
you can use any small NPNs like 2N3904 etc.
i have some 2N2222 lying around and they seem comparable to the one you mentioned, thanks for your answer i really appreciate it :)
