My first receiver was a Navy BC457 (ARC-5). Then BC348.
By the time I had the T-150 transmitter I was using a National NC183. In the car, I was 16 then, I had a Motorola 80D. First a 6 meter and then a 2 meter. The car was a 1958 Hillman Minx
This was in Van Nuys, California.
I looked at your circuit and decided to redraw it to make out what you have going on. See attached.
I can see why your unable to pull your crystal as your varicap is hanging on your output. Not sure if taking output off the feedback path is a good idea as the next stage will cause loading and detuning. What value cap do you have in parallel with the varicap?
I am not sure why your hanging a .01 cap in parallel with a 30pf cap on one side of your crystal. This would seem to put a rf ground on the one side of the xtal so the 30pf is useless.
I thought for a hartley osc the crystal should be in the feedback path, not shunt, but then again I do not have much knowledge in osc design.
But the sound quality is so bad that my wife and I cannot hear human speech. It is ducks quacking or whistles noises.The original article by Varmint stated - he liked the sound of it. Indeed it is "nice".
Communication's task is to "pass the message" and to do it in the max efficiency. The quality thus can be sacrificed. This is why CW will never die. It can get through when nothing else can. The quality has it's deserved space in listening to the music and hence the FM mode in the radio communication. But FM is wastefull on the RF spectrum and this is why it is used only on frequencies well above the shortways. In turn, it has limits to the "sure" range of reception. I am absolutely sure that the goal behind SSB is retained not in the quality but in the requirement to "pass the message" in the most power efficient manner![]()
No we aren't.we were talking about SSB here.
