bananasiong
Before I know the default value of the general purpose registers aren't zero, I didn't clear them and my LCD started with unexpected symbol ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
It seems out of topic![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
radix dec
; DelayUS() Macro Mike McLaren, K8LH, Jun'07 *
; simple macro "front end" for a 16-bit DelayTcy() routine that *
; allows you to specify delays in 'usecs' instead of 'cycles'. *
; the 'usec' delay range for a 16-bit target DelayTcy() routine *
; is based on clock frequency; *
; 4 MHz, 1 cycle /usec, 12..65536 usecs delay *
; 6 MHz, 1.5 cycles/usec, 8..43690 usecs delay * inprecise *
; 8 MHz, 2 cycles/usec, 6..32768 usecs delay *
; 10 MHz, 2.5 cycles/usec, 5..26214 usecs delay * inprecise *
; 12 MHz, 3 cycles/usec, 4..21845 usecs delay *
; 16 MHz, 4 cycles/usec, 3..16384 usecs delay *
; 20 MHz, 5 cycles/usec, 3..13107 usecs delay *
; 24 MHz, 6 cycles/usec, 2..10922 usecs delay *
; 28 MHz, 7 cycles/usec, 2.. 9362 usecs delay *
; 32 MHz, 8 cycles/usec, 2.. 8192 usecs delay *
; 36 MHz, 9 cycles/usec, 2.. 7281 usecs delay *
; 40 MHz, 10 cycles/usec, 2.. 6553 usecs delay *
; 48 MHz, 12 cycles/usec, 1.. 5461 usecs delay *
; the DelayUS() macro requires the following equate; *
clock equ 4 ; see list above
; DelayUS() macro; *
DelayUS macro usecs ; delay range: see list above
DelayTcy(usecs*(10000/(4000/clock))/10)
endm
; DelayTcy(), 12..65547 Tcy Mike McLaren, K8LH, Jun'07 *
; requires the use of constant operands known at assembly time! *
; 8 words, 1 RAM variable, 16-bit core *
; the DelayTcy() macro produces four instructions; *
DelayTcy macro delay ; parameter range 12..65547
movlw high(delay-12)+1
movwf TMRH
movlw low(delay-12)
rcall DelayLo-((delay%3)*2)
endm
; code for simulation testing; *
SimTest
DelayUS(65000) ; use the DelayUS() macro, or
; DelayTcy(100) ; use the DelayTcy() macro
nop ; put simulator breakpoint here
Delay.18F
nop ; entry point for delay%3 == 2
nop ; entry point for delay%3 == 1
DelayLo ; entry point for delay%3 == 0
addlw -3 ; subtract 3 cycle loop time
bc DelayLo ;
DelayHi
decfsz TMRH,F ; TMRH done? yes, skip, else
bra DelayLo ; loop again
return ;
