Clean: Deleting intermediary and output files.
Clean: Deleted file "F:\Raghav\f452tmpo.o".
Clean: Deleted file "F:\Raghav\f452tmpo.ERR".
Clean: Deleted file "f452tmpo.lst".
Clean: Done.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPAsmWin.exe" /q /p18F452 "f452tmpo.asm" /l"f452tmpo.lst" /e"f452tmpo.err" /o"f452tmpo.o"
Warning[230] F:\RAGHAV\F452TMPO.ASM 46 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 47 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 48 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 49 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 50 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 51 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 52 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 53 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 54 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 55 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Warning[230] F:\RAGHAV\F452TMPO.ASM 56 : __CONFIG has been deprecated for PIC18 devices. Use directive CONFIG.
Executing: "C:\Program Files\Microchip\MPASM Suite\MPLink.exe" "10f200.lkr" "F:\Raghav\f452tmpo.o" /o"Newbee.cof" /M"Newbee.map"
MPLINK 3.94, Linker
Copyright (c) 2005 Microchip Technology Inc.
Error - section '.config' can not fit the absolute section. Section '.config' start=0x00300000, length=0x0000000e
Errors : 1
BUILD FAILED: Tue Sep 12 12:18:19 2006
Micro82 said:As for the A/D results yes you can change the reading from 10bit to 8bit this is setup in one of the A/D control registers.
user1453 said:only the home page of your site is active
and to be honest usb support is very good for me personally
