So i have the mamod steam engine now, i also have another dual piston steam engine coming. These are model scale, however the gas system is lab scale so this is not a barrier.
The idea is to test a method of pre-treating certain bio fuel digesters. The reason for using a steam engine is because it has all the component parts of the process needed. It can be used to generate electricity, it has steam and heat and with a modification it can compress or create a vacuum.
The mamod engine is very small and unlikely to be useful, however the engine is large enough but dosnt have a boiler, so the idea is to use the boiler on the mamod as the safety valve and build another boiler to power the larger engine, the mamod also has some parts on that are needed to modify the mechanical side of what we are trying.
Sounds daft, however when you see how the current process is carried out, a steam engine makes alot of sense, it would not be running all the time, mainly just for batch processing certain feedstocks as they come in.
I have opened this here as a couple of others are helping me work on it. Most of the control side is fairly simple, so fully automating it should not be to hard. If we can prove the principle then the engines become a good demonstration unit at the lab scale.
First job is build a tacho!! And i need to be able to measure voltage and control two or three small model servos, once thats done we can start the main conversion.
I will get a pic of the mamod i finally got working
, i got lazy and used methanol instead of meths because i didnt have any meths handy, that totaly clear flame gets you every time ![Big Grin :D :D](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
