Stepper motor driver
If you take it down prior to getting an answer you will not get one.
It is a risk you have to take (or not). I do not think anyone here is interested in helping you using PM. Most often it is a team effort anyway.
3v0
3v0
yeap i understand that its a risk and it is team effort..
Do u have any comment about the schematic sor far?
thnx
I do not recall a PIC with that number.
Are there VSS and VDD connections to the PIC ?
There is an unmarked 8 pin chp that looks like a driver or level shifter. Most often I2C does not use one. Keep in mind the SDA line can be driven by either the master or the slave. That would be a problem here.
I do not see an ICSP connector. Don't leave home without one :)
3v0
3v0
Its a microcontroller
the unmarked 8 pin chip is the I2C bus buffer.
I didnt understand the highlited text..
Thanx alot for ur comments and help so far.
OK I see it is a NPX uC.
OK if specificaly designed for I2C. Put the part
number on it. But it is only needed for long distances.
If the buffer is sold as an I2C buffer ignore it.
Good luck.
