Please confirm if i would go for 5-6 Amp Constant OutPut.qamarbukhari,
A resistive voltage divider is totally unpractical at your current requirements. Even a linear regulator would produce (48-36)*15= 180W of heat. This would require a huge heatsink.
This is a job for a SMPS buck converter with an overall efficiency of ~85% which would reduce the power dissipation to about 30W.
Is is 5 amps or 6 amps?
What regulation do you want?
How much higher than 36v can the output go to?
Is the 6A a CONSTANT value?
What is a "15 amp module?"
Here's a simple circit to increase 5v to about 7v:
