Oh, you get the correct result, but not the wanted result
You want the waveform to be inverted, but not the duty cycle to be complemented.
You cannot use this: PORTB = ~CCP1 because the result on PORTB is parallel. The easiest way is to use a hardware inverter at the output of CCP1.
Or, is the program running anything else? If not then you can update the duty cycle of CCP1 in the timer 2 ISR. In the main, poll RC2 (CCP1) and invert this pin to any output pin. Or anyone has better solution?
I just looked at the chip your using, check the function of bit 6&7 of CCP1CON. In fact, I think you can set the chip up so that CCP1 output is inverted - see page 147 of the data sheet.
Hi Pommie,
Another thing, can PIC do deadtime timing delay?
#include <P18F4520.h>
#include <timers.h>
#pragma interrupt interrupt_1
void interrupt_1 (void);
void main(void)
OpenTimer0( TIMER_INT_OFF & T0_8BIT & T0_SOURCE_INT & T0_PS_1_256 );
if (INTCONbits.TMR0IF=1)
interrupt_1();
void interrupt_1(void)
// Interrupt Code - For example like reading analog input
#include <timers.h>
void main(void)
interrupt_1();
INTCONbits.TMR0IF = 0;
If you have a look at this thread, about a dozen posts down I posted some code showing how to setup the interrupt vector and routine. From this you should be able to work out how to do your interrupt.
BTW, a 1μS interrupt is very fast. Are you sure you don't mean 1mS?
