DigiKey sells hundreds of more modern NFETs called "logic-level FET" that are fully-turned on for conduction with Vgs less than 5V.
Look at the table in the link above. You can filter it down to a shorter list as you add constraints for Vds, Ron, what type of package, how much you can pay, etc.
Any other solution?I was hoping something like "Go ahead it will work"...
Sure, raise the supply voltage. Use an SMPS or charge pump to raise the gate voltage, all of which will cost more than just buying a modern NFET.
If he can get the full 6V to the gate, and if the NFet is on a good heatsink, it will work for a hobbyist. I wouldn't go into production with it...It will work.
That sounds great. Its one time thing hobby purpose, as long as it works i am happyIt will work.
