You have go to cut me a little slack. I know that if I connect the positive of a battery to the earth current will not flow unless I had the other terminal connect to earth also. I was just kinda thinking of the ground in a circuit. You know on spice how you always have to put in a ground even though you dont really need one for DC.
That's a side effect of how spice works, not a side effect of how the real world works. Spice simulators work through mathematical models, not by modelling the actual physics of the materials involved.
But anyways what I am getting at is this; are you completely sure that your energy is being converted to heat as it passes through a resistor?
Well, given that the amount of heat produced in a resistor is equal to that predicted by current physics theory for a given resistance, voltage, and current, yes, I'm pretty confident.
Or is the heat a by product of the electrons passing through it.
Not "or", "and". Yes, it is. More precisely, it's the charge which is moving more than the electrons (which are also moving but much more slowly than the charge).
Also, are you sure that just because power is stored in an inductor it is being consumed?
No, and that doesn't make any sense anyway, as it's contradictory. I'm quite certain that the charge which is stored in an inductor is stored in the inductor, not consumed by the inductor. Energy which cannot be reclaimed cannot be said to have been stored.
Are you certain you cant get that power back?
No, and I didn't say that. The stored energy in an inductor can be gotten back--otherwise we would not say that the energy had been stored; we'd say it had been consumed. Some energy can be consumed (say, into heat by internal resistance, or into magnetic force) but then we don't say that this energy has been stored by the inductor--although we can store some of the converted energy, for instance, as kinetic energy in a flywheel. This energy can of course be at least partially reclaimed.
What I have noticed in my experiments is that voltage seems to play a very big role in charging lead acid batteries. That is how the Tesla switch recaptures most of its energy.
Voltage is important in any battery charger, as is current.
Again, are you planning on publishing any of these test methodologies, setups, and results of yours which you keep referencing? I really would like to try to replicate some of your results.
Torben
