I was just about to make the point that Frank has made here.
I didn't notice in this thread if anyone admonished you to check the diodes, triac, and resistor resistance by lifting leads off the board. I noticed you gave diode ohmic measurements and said the diodes read "000" either way. Well, even in circuit this shouldn't be the case but I never trust "in circuit" resistance readings. Been burned too many times by overlooked parallel components!
Honesly, the best way to troubleshoot a circuit like this is on an AC voltmeter point-to-point with voltage applied but I understand if you aren't familiar with electronics that this wouldn't be the time to start learning
Just a hint if you are willing to try measuring the operation of the circuit with power applied, if there is an open circuit, chances are you will read the full AC supply voltage dropped across the faulty component. That would be the voltage at your wall outlet unless there is an external transformer somewhere that we aren't aware of. And all of this assuming the reverse-engineered schematic that someone posted was correct.
