Anniyan_x
HI there
currently i have input card, the configuration is as attached image View attachment 63917, i can connect drycontact based sensor/switch to it. basically a channel is activated when the channel is short to ground/common.. but now i need test the channel contact response by giving a 100ms voltless pulse(dry contact) meaning i need to short the common&DI channel for 100ms and check if the card can detect or not. im now not sure how to physical short it for 100ms, what type equipment i need to use, i have a pulse generator but that give a voltage based pulse, i do have a scope to.. but how to test dry contact...anybody have some ideas or any equipment that usualy can be used for this type of input testing.
wt rgds
anniyan
wt rgds
anniyan
