TFT display with ST7735 - brightness
Andy_123
Hello,
We have bunch of 1.8" TFT displays from multiple vendors.
Some are shiny and bright, but some are quite dim.
These are "no-name" displays are from multiple vendors without exact datasheets.
I am trying to figure out if I can do something to increase brightness for these dim panels so we can use them in prototypes and demo's.
I have more than 100 of these.
My first attempt was to increase backlight current, but even with 30mA (20mA nominal) these are not bright enough.
So I am thinking if these may need a different INIT values that we should be using.
Without displays datasheets, I can use only ST7735 information, but I am not sure what to change, so I am looking for ideas.
We power them from about 3.4V (both LCD and PIC)
Below is my current INIT code, credit to Adafruit libraries, but I am using it with a PIC microcontrollers.
Thank you in advance.
ST7735_SWRESET,   DELAY,  //  1: Software reset cmd1, 0 args, w/delay
      150,                    //     150 ms delay
ST7735_SLPOUT ,   DELAY,  //  2: Out of sleep mode, 0 args, w/delay
      255,                    //     500 ms delay
ST7735_FRMCTR1, 3      ,  //  3: Frame rate ctrl - normal mode, 3 args:
      0x01, 0x2C, 0x2D,       //     Rate = fosc/(1x2+40) * (LINE+2C+2D)
ST7735_FRMCTR2, 3      ,  //  4: Frame rate control - idle mode, 3 args:
ST7735_FRMCTR3, 6      ,  //  5: Frame rate ctrl - partial mode, 6 args:
      0x01, 0x2C, 0x2D,       //     Dot inversion mode
      0x01, 0x2C, 0x2D,       //     Line inversion mode
ST7735_INVCTR , 1      ,  //  6: Display inversion ctrl, 1 arg, no delay:
      0x07,                   //     No inversion
ST7735_PWCTR1 , 3      ,  //  7: Power control, 3 args, no delay:
      0xA2,
      0x02,                   //     -4.6V
      0x84,                   //     AUTO mode
ST7735_PWCTR2 , 1      ,  //  8: Power control, 1 arg, no delay:
      0xC5,                   //     VGH25 = 2.4C VGSEL = -10 VGH = 3 * AVDD
ST7735_PWCTR3 , 2      ,  //  9: Power control, 2 args, no delay:
      0x0A,                   //     Opamp current small
      0x00,                   //     Boost frequency
ST7735_PWCTR4 , 2      ,  // 10: Power control, 2 args, no delay:
      0x8A,                   //     BCLK/2, Opamp current small & Medium low
      0x2A,
ST7735_PWCTR5 , 2      ,  // 11: Power control, 2 args, no delay:
      0x8A, 0xEE,
ST7735_VMCTR1 , 1      ,  // 12: Power control, 1 arg, no delay:
      0x0E,
ST7735_INVOFF , 0      ,  // 13: Don't invert display, no args, no delay
ST7735_MADCTL , 1      ,  // 14: Memory access control (directions), 1 arg:
      0xC0,                   //     row addr/col addr, bottom to top refresh
ST7735_COLMOD , 1      ,  // 15: set color mode, 1 arg, no delay:
      0x05 },                 //     16-bit color
ST7735_CASET  , 4      ,  //  1: Column addr set, 4 args, no delay:
      0x00, 0x00,             //     XSTART = 0
      0x00, 0x7F,             //     XEND = 127
ST7735_RASET  , 4      ,  //  2: Row addr set, 4 args, no delay:
      0x00, 0x9F,           //     XEND = 159
ST7735_GMCTRP1, 16      , //  1: Command 0xE0, Gamma 16 args, no delay:
      0x02, 0x1c, 0x07, 0x12,
      0x37, 0x32, 0x29, 0x2d,
      0x29, 0x25, 0x2B, 0x39,
      0x00, 0x01, 0x03, 0x10,
ST7735_GMCTRN1, 16      , //  2: Command 0xE1, Gamma 16 args, no delay:
      0x03, 0x1d, 0x07, 0x06,
      0x2E, 0x2C, 0x29, 0x2D,
      0x2E, 0x2E, 0x37, 0x3F,
      0x00, 0x00, 0x02, 0x10,
ST7735_NORON  ,    DELAY, //  3: Normal display on, no args, w/delay
      10,                     //     10 ms delay
ST7735_DISPON ,    DELAY, //  4: Main screen turn on, no args w/delay
      100                   //     100 ms delay
These are brand new, never used, and making backlight brighter does not really help.
Also replacing hundreds of backlights are not very practical on $3 display.
I think that issue is that these my need a different init parameters for power control, but I am not sure what to change.
thanks
