WOW! Thank you for your responses!
What do you think the significance of them using the frequency sources as 1:2 frequencies (600Hz and 1200Hz) is? How would you utilize this fact?
I also agree that this is probably not a coincidence that they have chosen it to be this way.
Arhi, I must agree with you on the amplitude attenuation, I don't think (according to my knowledge of the physics) that the amplitude will change very much over such a short distance. In your method, would you plan to calculate the phase difference received between the two mic's (placed at a distance apart from each other) by calculating the time difference between peak readings by either mic? I have read up on this and this technique is known as 'interaural time difference'. It is the basis upon which humans are able to localize sound. It seems like a feasible solution.
Do you think though that having the interference pattern it will be possible to adequately separate the two frequencies by filtering? Will the interference pattern be a 'standing' one, having distinct areas of interference, or will the pattern of interference be changing and repeating itself?
Bobledoux, we have been told that we will be able to make measurements at various areas in the test area, however I do not think this will happen very long before actual testing. Therefore I think it may be necessary, if possible, to develop a technique to calibrate the robot each time it begins its 'journey'. Odometry sounds like a good way to confirm distance travelled relative to the robots last point.
I think this could be used to supplement the audio measurements. A comparison between the two measurements could be made.
