MacIntoshCZ
Active Member
I would like to make some shielded boxes for several diy PSUs. Do you have any idea whats cheapest way to do it? If I buy a metal plate, the box itself will be more expensive than all electronics
ThanksFor custom metal fabricating I make use of the Tin 1Kg coffee containers, easy to work if you have tin shears etc, also easy to solder.
The non-ribbed can is preferable.
How good tinfoil can block radiation? If a remember i tried once to cover smartphone with tinfoil and play music from youtube. It not works. Wifi still worked
How did you prevent YouTube from buffering the entire song before you finished wrapping your phone?How good tinfoil can block radiation? If a remember i tried once to cover smartphone with tinfoil and play music from youtube. It not works. Wifi still worked
I played live radio-castHow did you prevent YouTube from buffering the entire song before you finished wrapping your phone?
