Matt Bower
I know almost nothing about electronics; I'm basically hoping some of you kind folks will take pity on me and walk me through my proposed project. Please expect me to ask stupid questions.
My problem is this. I have an oil burner that I salvaged from a residential furnace. I want to use it to heat a small casting/heat treating furnace. I want to be able to select a furnace temperature, turn on the burner, and have it heat the furnace to the selected temperature and maintain it there by cycling on and off as necessary.
The temperature range that's of most interest to me is around 1200 F - 2000 F. I plan to use a Type K thermocouple as my sensor. The idea is to use the potential across the thermocouple terminals to trip a relay that shuts down the burner once it reaches the selected temperature, then cycles it back on again as the furnace begins to cool. (At least that's what someone suggested to me. I didn't know what a relay was until I looked it up.) Since I want the burner to come on and remain on until the selected temperature is reached, then come back on once the temperature begins to fall, it'll need to be a normally closed relay.
In the temperature range I'm most interested in a Type K thermocouple should produce roughly 25 to 45 millivolts. I'm not sure whether I need a relay that will trip in that range, or whether I should get a relay that trips at some higher voltage and then somehow multiply the voltage across the thermcouple. (I know that can be done, but I have no idea how to do it.)
My main question is how to make furnace temperature selectable. I know very little about relays, but I gather they're built to open or close at a single, constant voltage. I want my relay to trip at any point along a wide range of voltages, depending on what I've selected. How do I do that? The same guy who suggested the relay also suggested a potentiometer, which I could calibrate by hand by measuring the temperature in the furnace at given potentiometer settings. (I have an inexpensive thermocouple thermometer that I could use for calibration.) But I'm not sure I understand exactly how that'd work.
My next questions are what sort of relay I'd need, and where to get one. (The burner runs on 120V/60Hz and draws a maximum of about 6 amperes.) Assuming I do need a potentiometer, the same questions apply.
Thanks in advance for any help.
