This part is driving me nuts .....
As the existing design has an obvious design flaw (hence the reason for the diodes mechanically breaking), is there space to fit a different diode the other way up?, and solder wires from the diode to the PCB?. This would solve your pinout problem, and cure the breakages.
Read post 11 carefully. You can mount the bridge rectifier off-board and solder the jumper wires into the through-holes of the original component. Just use fat enough wire to handle the current expected.
