Hello there,
I *could* start by griping about the current state of USB and data transfers .............. so i *will*![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
To start, USB data transfers depend a lot on the system and USB drive itself. I've tried a lot of different options, included USB drives that are advertised as being very fast (150MB/s) and i find some very very serious problems with USB, even USB 3.0 which was the current standard up to maybe several months ago when USB 3.1 came about. I found that the specifications on USB 3.0 are very very misleading and really absolute trash talk really. I'll elaborate here.
First, USB 3.0 can transfer large files pretty fast if the USB drive can handle it. That's not too bad, except for people demanding top speed, and then we find that the 500 megabytes per second quote is not true at all, and with overhead and all it comes down as low as 300MB/s and maybe you'll see 350MB per second if lucky and have the right drive, and that's probably with UASP enabled (another relatively new USB standard).
But for me, 300MB/sec would be just fine. The problem is, that's only with larger files. If we transfer one 1 gigabyte file we might be able to do it in 4 seconds, which isnt bad at all (i clocked 5 to 6 seconds on one of my drives). However, if we transfer that same amount of data but they are a bunch of small files, the transfer rate falls AT LEAST by 10 fold. So for that same 1GB data if that was 10000 files that were 100k each, the transfer rate could fall as low as 5 megabytes per second, but more typically 10 to 20MB/sec, and that's with a very very fast USB drive of the SSD type. I've read that 12MB/sec is the norm here.
So what happened? From 300MB/sec to 12MB/sec? That's just nuts. Somebody messed up somewhere.
I also tried using a Sata to USB converter cable/power supply with standard SSD, but it topped out at 20MB/sec. To be fair though, the converter was made for USB 2.0 and i didnt feel like buying a new one for USB 3.0 because i am afraid that the performance will still be too low.
Ok so i am done complaining, at least for a moment because i will never stop complaining about this one![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
To move on, i thought about using an external Sata drive. the external drive would plug into the mother board eSata port or a PCIe card could be purchased and plug the drive into that. Using a good regular SSD drive, we could easily see transfer rates of 400 megabytes per second, and depending on the IO transfer rate of the drive, probably 100MB/sec for groups of small files. 100MB/sec isnt too bad really, and i could live with that. It's just hard to live with 10MB/sec when the drive itself is much much faster than that.
So to sum up, using a USB SSD drive i can get normally probably 15MB/sec most of the time, but using an external Sata can probably get 100MB/sec most of the time, so i might move to using eSata instead. The Sata SSD drives are very light weight and easy to carry in a pocket, although not as nice as a regular USB drive.
I do have reserves about this though. The main worry is about the Sata and Power connectors on the SSD drive. I dont think they are made for thousands of insertions and removals. I could be wrong because i have seen 'docking' stations that quote 50000 insertions but i dont know how accurate that figure is.
So in short, i wonder how many insertions the drive would take before it started to fail now and then.
I know i could make up an adapter, and that would put the burden on the adapter, which could be changed periodically, but, that would make the drive harder to carry around (it has to be portable).
A secondary issue is that the external drive might read at 15MB/sec for small files the first time they are read, but then what is strange is the second time they are read they read at 150MB/sec !! Is that strange or what?
Any ideas on any of these topics?
To recap the topics were:
1. Sata connector insertion issue.
2. Read once slow, read second time fast.
Any ideas would help as i have been wrestling with these issues for several years now. I am about to do something drastic but it would take a lot of work and time so i would like simpler ideas.
