timer circuit
alamy said:
pls comment my program flow..
read input (set 31 as setpoint ; branch to TurnOn/TurnOff) and i'll have two table ....
Read	Movf       PORTB,w
                Subwf     SP,w  ; where SP define as 31 (b’11111’)
                Btfss       STATUS,C  ; I’m not sure use this one….
                Call        TurnOn
                Call        TurnOff
There are a couple of problems here, firstly why the SUBWF?, secondly 'Call TurnOff' will always execute because 'Call TurnOn' will return from it's subroutine and execute the next line.
How about this:
Read	Movf       PORTB,w
                movwf    TempW
                Btfss       TempW, 5  ; test bit 5
                Call        TurnOn
                Btfsc       TempW, 5
                Call        TurnOff
                Goto       Read
This assumes you wanted TurnOn and TurnOff as subroutines, because you used 'CALL'. If you used 'GOTO' instead you could remove the BTFSC line. I notice that your TurnOn and TurnOff routines don't have RETURN or RETLW at the end so you mustn't use CALL to run them, you must use GOTO instead - or add RETURN at the end of each.
The routine with GOTO then becomes:
Read	Movf       PORTB,w
                movwf    TempW
                Goto        TurnOn
                Goto        TurnOff
Another way of doing it, would be to use the full 64 byte table, but for the second half of the table have bit 7 set in the entries, then after reading the table test bit 7, and turn On or OFF accordingly - remembering to mask off bit 7 before calling the delay
i've no idea on this...
If you don't understand it, just ignore it and use the existing way, it's just a variation on the same theme.
Nigel how about my TableOn?…after test bit 5, it will go to TurnON or TurnOff, then in my TurnON subroutine, I include TableOn which start from 32 up to 63(?), but how do modified my table ?..in my TableOff, there’re only 32 bytes(am I right?)
My code:
   list      p=16F84A            ; list directive to define processor
   #include <p16F84A.inc>        ; processor specific variable definitions
   __CONFIG   _CP_OFF & _WDT_ON & _PWRTE_ON & _RC_OSC
cblock
d1
d2
d3
d4
count1
endc
; '__CONFIG' directive is used to embed configuration data within .asm file.
; The lables following the directive are located in the respective .inc file.
; See respective data sheet for additional information on configuration word.
; CIRCUIT FUNCTION
; to implement the inference engine for digital fuzzy controller to control
; the compressor action.
; single means - off, low , medium or high
;***** VARIABLE DEFINITIONS
STATUS     EQU     03h      ; variable used for context saving
TRISA      EQU      85h        ; variable used for context saving
PORTA      EQU      05H
TRISB      EQU      86h
PORTB      EQU      06h
TempW	   EQU      1
      ORG     0x000             ; processor reset vector
      goto    main              ; go to beginning of program
      ORG     0x004             ; interrupt vector location
main    bsf     STATUS,5         ; bank 0 -----> bank 1
	    movlw   b'00000000'       ; set the port a as outputs
	    movwf   TRISA             ;
	    movlw   b'00111111'       ; set the port b as inputs
	    movwf   TRISB
	    bcf     STATUS,5         ; bank 1 -----> bank 0
Read    movf    PORTB,w
	    movwf   TempW
	    Goto    TurnOn
        Goto    TurnOff
TurnOn 	andlw 	b'00011111'; should i change to b'00111111', 32 or 64 bytes?
	   	Call 	TableOn
	   	Call 	DelayW
		bcf  	PORTA
		Goto 	Read
TurnOff andlw 	b'00011111
        Call 	TableOff
	   	Call 	DelayW
		bsf  	PORTA
        Goto 	Read
;oooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooooo
; Delay = 300 seconds
; Clock frequency = 4 MHz
; Actual delay = 300 seconds = 300000000 cycles
; Error = 0 %
DelayW  movwf   count1
Delay5          ;299999995 cycles
 	    movlw   0x54
	    movwf   d1
		movlw   0xA1
		movwf   d2
		movlw   0xFD
		movwf   d3
		movlw   0x02
		movwf   d4
Delay_0
		decfsz   d1, f
		goto   $+2
		decfsz   d2, f
		goto   $+2
		decfsz   d3, f
		goto   $+2
		decfsz   d4, f
		goto   Delay_0          ;5 cycles
		goto   $+1
		goto   $+1
		nop
		decfsz   count1   ,f
		goto   Delay5
		retlw   0x00
TableOff Addwf PCL,f
	   	Retlw  1	;0
	   	Retlw  1	;1
	   	Retlw  2	;2
	   	Retlw  1	;3
	   	Retlw  3	;4
	   	Retlw  1	;5
	   	Retlw  1	;6
	   	Retlw  2	;7
	   	Retlw  1	;8
	   	Retlw  3	; 9
		Retlw  1	;10
	   	Retlw  1	;11
	   	Retlw  2	;12
	   	Retlw  1	;13
	   	Retlw  3	;14
	   	Retlw  1	;15
	   	Retlw  1	;16
	   	Retlw  2	;17
	   	Retlw  1	;18
	   	Retlw  3	;19
	   	Retlw  1	;20
	   	Retlw  1	;21
	   	Retlw  2	;22
	   	Retlw  1	;23
	   	Retlw  3	;24
	   	Retlw  1	;25
	   	Retlw  1	;26
	   	Retlw  2	;27
	   	Retlw  1	;28
	   	Retlw  3	;29
	   	Retlw  1	;30
	   	Retlw  3	;31
TableOn Addwf PCL,f
	   	Retlw  2	;32
	   	Retlw  2	;33
	   	Retlw  2	;34
	   	Retlw  2	;35
	   	Retlw  3	;36
	   	Retlw  3	;37
	   	Retlw  2	;38
	   	Retlw  2	;39
	   	Retlw  1	;40
	   	Retlw  3	;41
		Retlw  3	;42
	   	Retlw  2	;43
	   	Retlw  2	;44
	   	Retlw  1	;45
	   	Retlw  3	;46
	   	Retlw  1	;47
	   	Retlw  2	;48
	   	Retlw  2	;49
	   	Retlw  1	;50
	   	Retlw  3	;51
	   	Retlw  1	;52
	   	Retlw  1	;53
	   	Retlw  2	;54
	   	Retlw  1	;55
	   	Retlw  3	;56
	   	Retlw  2	;57
	   	Retlw  2	;58
	   	Retlw  2	;59
	   	Retlw  1	;60
	   	Retlw  3	;61
	   	Retlw  1	;62
	   	Retlw  2	;63
      END                     ; directive 'end of program'
And I get this message
Clean: Deleting intermediary and output files. Clean: Done. Executing: "C:\Program Files\MPLAB IDE\MCHIP_Tools\mpasmwin.exe" /q /p16F84A "delay.asm" /l"delay.lst" /e"delay.err" Warning[205] I:\PROGRAMMING\DELAY.ASM 9 : Found directive in column 1. (cblock) Message[313] I:\PROGRAMMING\DELAY.ASM 9 : CBLOCK constants will start with a value of 0. Warning[205] I:\PROGRAMMING\DELAY.ASM 15 : Found directive in column 1. (ENDC) Message[302] I:\PROGRAMMING\DELAY.ASM 44 : Register in operand not in bank 0.  Ensure that bank bits are correct. Message[302] I:\PROGRAMMING\DELAY.ASM 46 : Register in operand not in bank 0.  Ensure that bank bits are correct. Error[128]   I:\PROGRAMMING\DELAY.ASM 58 : Missing argument(s) Warning[209] I:\PROGRAMMING\DELAY.ASM 61 : Missing quote Error[128]   I:\PROGRAMMING\DELAY.ASM 64 : Missing argument(s) Halting build on first failure as requested. BUILD FAILED: Wed Sep 29 10:58:09 2004
An error occurred at bcf and bsf line….WHY?
pls advice...
thanks in advance
i'm sorry the message should be like this
Clean: Done.
You need to add an extra line to the beginning of Table OFF:
ANDLW  b'00011111'
To mask off the extra bit.
Because you haven't got enough arguments in it!. You need to specify the PIN which you are switching, like this:
bsf PortA, 1
The error message about CBLOCK is simple, you need to tab it over to the second column - the first column is reserved for labels.
you need a tab before the cblock, to move it to the second column
You need a value behind cblock to set the data's start address. For the 'F84 that would be 0x0C
Not an error, but a warning. You're using a variable wich is not in bank 0, the compiler warns you to check you switched to the correct bank.
You can supress these errors by adding 'ERRORLEVEL -302' to the top of your code.
Nigel already explained the BSF and BCF errors.
