I need to build something to lift a bit of wood in response to a start event (e.g. a button press), and then 20 or so minutes later allow the wood to drop again (this can be a simple gravity drop).
The wood is thin and about 36" long x 6" wide - so not overly heavy. It is fixed to the sides of something at the back 2 corners (36" in-between) and then the front just drops until it hits the floor (roughly an angle of 45 degrees although this is probably irrelevant).
It's hard to describe - think of it as a sort of wooden cat flap that is mounted horizontally rather than vertically, so that the flap just drops down andd touches the ground! The idea is to lift the flap when a button is pressed, hold it up for 20 mins, then let it fall again.
Ideally this will be a smallish device (has to fit inside something) and will be low current & battery operated - although mains powered is possible if necessary.
I've no real experience of this kind of thing so am a bit stumped - can anyone offer any suggestions/help please?
