Tiny Wind Power - Next Step
Re the cogging (stepper detent torque) that was why I suggested multi blades. With a stepper you dont need high rpm like most mills, you need a high torque low rpm turbine.
Re the blades backwards, the face of the blade (facing the wind) and the leading edge should be flat, the trailing edge of the blades goes "back" which puts its drag in the rear of the blade movement and the rear of the wind direction (ie low pressure zone).
That way needs less clearance, most of those pictures show little clearance between the hub and the generator housing. There's probably not that much difference in the efficiency on small turbines anyway.
