hello every one i am confused of so many formulas about transformer rewinding... can you help with simplified formula of calculating... example 0-220v primary and 50v-0-50v sec at 10ampere ct... thanx.... JINGz
Why not just buy one?
50V-0-50V is a pretty common output voltage, it's not like you require anything specialised.
Shouldn't you include primary inductance? Of course, you did say "As a minimum...".Hi there,
When working with transformer windings you have to exercise some concern
about at least a minimum number of issues or you wont get something
that will work the way you expect it to.
As a minimum, you need to think about these issues:
1. Turns ratio
2. Maximum flux density
3. Primary wire diameter (wire gauge)
4. Secondary wire diameter
5. Primary winding resistance
6. Secondary winding resistance
7. Control of winding to winding isolation
8. Control of layer to layer winding isolation
9. Total power dissipation/heating at full load
Considering all of the above leads to a decent design
which could last a long time.
Skip any *one* of these issues and you could end up with something
that either doesnt work the way you want it too, doesnt work at all,
burns up after a short time of use, or works for a while and then
sometime later shorts out and blows the fuse or burns up.
If you are still interested let me know.
i want to try this formula by rebotexx but im wondering where does 5.775 came from..
for me this is a simplified example...
The formulas is the easy part. The actual fun is when you really try to wind the thing. Do you have tooling for such a project?
