Transformer
S-fr
Hey there ,
I got a transformer that is 25-25-0 plus 12-12-0, both em are dual output i need to know if i can just connect em in this same order to get more voltage ik, at the end the total watts will be the same, and if that's possible, is this safe?
IF (big if) the 25-0-25 group is completely isolated from the 12-0-12 group, then
maybe.
If the transformer is in fact 25-12-0-12-25. then a big NO.
ak
Hey there ,
Post the resistance across the outputs. What is the resistance between the two 0V secondaries?
What is the power required, V and I ?
Transformer datasheet, post .
Regards, Dana.
Well its a locally made one so there no datasheet, and i need somewhere between 35-0-35 and 40-0-40
We are trying to determine if the 12 V windings and the 25 V windings are galvanically isolated. What is the resistance between one of the 25 V wires and one of the 12 V wires?
a) multi-megohms or infinite
b) anything else
ak
do you mean like this? This is 1:2 centre-tapped. That won't give 35~40 out on each leg.
Version A cannot be adapted for various voltages, version B can be added to get higher voltage. Measuring resistance from zero to zero on A will be a short, on B it will be infinite.
No, i check its myself its 25-25-0v, giving me like 49.8vac something and 12-12-0 and its giving me like 25vac
Now the question is, does your meter read "True RMS" AC voltage, peak AC voltage or ...? Which meter are you using (brand and model number).
Note that the max current output of the two windings in series, is the the max of the winding with the lowest rating.
All multimeters are designed to read the RMS voltage of a sinewave.
Since this is a transformer sine-wave output, whether the meter is average responding, calibrated to read RMS, or a true RMS meter will have a negligible difference on the value measured.
