Nikolai Petrenko
Or can you send me all schematic files .sch? then my older-friends will have me turn they into PCB layouts
Hmm, I just realized that dual rail supply will be better than single ones. Why? You said that the circuits can be improved by increase the supply voltage and change some resistors. Now supply volt for subwoofer is 60V, while maximum volt of filter capacitors is 63V. So if I improve the amp in the future, capacitors will explode. If I use dual rail supply, only above 30V on each caps
Wow, you said that you have been hang up your soldering iron, so you busy because of children or extra works? I just ask because I am to curiouslyNo problems Nikolai,
Why not learn how to do it in Eagle. A bright chap like you should have no problem. You can then use the printout to make a PCB by hand. The only reason I can't do a layout is that I simply do not have the time to learn and do the job, as I said, much as I would like to.
I have been spoilt; when I was at work someone else always did the job for me. I have never laid out a PCB with ECAD- done plenty by hand using trace black tape though.
Of course! I was wanted to ask you sth. about the output coupling caps but you have answered before I asked. I have thought that OCL circuits amp will be cheaper and better because they don't have output coupling caps. Electrolytic cap isn't linear, I have tried it in my LA4440 amp, I know that DC current can harm my speaker but when I remove output cap, the sound betterPS: I meant to say that if you go for dual supplies without the big output coupling capacitor, you will not be able to use the latest 20W and 40W amp designs. You will need to have a long-tailed front end to get a low output offset. As a result you would be moving over to voltage frredback rather than current feedback. Current feedback is best but with good circuit design voltage feedback can be made just as good, in practical terms.
I agree to use new circuits. This project is one of my very very few projects that I decide to spent a lot of money (I am not make money appreciably yet) so I want it as good as my condiction can allow.
I want some suggests about resistors and caps:
- what type of resistors I should use? I found some stores sell vishay, dale, koa,... resistors, those resistor have 5 colours strips and blue paint coated so I think they are metal film. I am not found stores that sell carbon composite resistors yet. Carbon composite have lowest capacitance and inductance while metal film have lowest noise (some friends said that carbon composite provide more nature and warm sound).
- I know input capacitors can affect the sound quality a lot so their characteristics must be linear. Not just run to the market and ask for 10uF electrolytic caps but ask for 10uF polypropylene caps as you said. Is it necessary to buy polypropylene caps for other caps like 100nF and 22uF...
Wow, you said that you have been hang up your soldering iron, so you busy because of children or extra works? I just ask because I am to curiously.
Now I still don't have anything about Eagle in my brain. I don't know how to put components from library to the draw page, my version of Eagle is 7.5.
Thanks. I want schematic and make the pcb myself. Kits are more expensive than discrete onesHi Nicolai,
I hope you don't spend too much money.
Can I say that if you are spending money it would be cheaper and simpler to buy a kit of parts for a ready designed and tested amp. There are many on the net that would suit your needs.
Also, please do not not spend any of your hard-earned cash untill you have the case, power supply, and heatsinking designed, built and working- this is most important
Resistors
Metal foil resistors are the best type for high quality audio work. (inductance and capacitance are not too important). Metal film are the next best and far less expensive than metal foil.
The next quality resistor is tin oxide, but they do not sound as good as metal foil and film. Tin oxide are very stable and rugged and are best for general electronoic projects. Because they are so reliable and stable, they are the military's preferred type- they are all I used at work.
Carbon composition resistors are liked by the valve boys, but I have not found them to be brilliant for solid state amps. I think it is because valve circuits have low currents and high voltage, while solid state is the other way around. Carbon film have very little going for them and are best avoided for all work.
There are also wire wound and ceramic composition power resistors (1W upwards). Special low inductance wire wounds will be required for the two low value resistors in the output transistor emitters.
Capacitors
Yes, polypropolene caps are what you want for the solid caps. Electrolytic capacitors should be a good quality type, established as sounding nice, Rubicon and Alps for example.
Don't put ceramic capacitors anywere near the audio signal path or you will get a brittle disturbing sound. The first half decent amp I built had ceramics- it sounded awful.
Having said that, there is asoulutely no reason why you could not use ceramics to get the amps going. Later you can fit what you want.
Polystyrene also sound good, but you only get themin low capacitance values. Silver mica are very nice, but expensive and also not available in high values
Most run-of-the-mill solid capacitors are polyester. They are cheap and easy to get. They do not sound too bad either. My advice would be to use those if you find polycarbs are too expensive or hard to get. later you can upgradw. polyester caps are not good for decoupling though.
In the dual supply version of the amp only the input capacitor is idirectly n the audio signal path, so that is the one to concentrate on the most.
Once again- do the case, PSU and heatsinks before you spend any money elsewhere. If you like I will do a sketch to show how I think the case should be, or I can just leave it up to you- it is your choice.
An audio amp from scratch is a really tough project. I did some looking ans found this: **broken link removed**
Let's have spec rip it **broken link removed** apart design wise.
My initial comments are
1. The bias regulator can be improved more mechanically than anything else.
2. Independent supplies is another.
I would like to see 3 diodes rather than two for easier mounting. And the diodes mounted direct to the heatsink.
The cost seems cheap until you add case/power supply etc.
We/spec can offer suggestions that can make the amp better.
This **broken link removed** company has always intrigued me.
I will repeat that The Leach Amp is fantastic.
Capacitor ratings of 1.5 to 2x the supply is good. I put ZNR's across the main filter caps to eliminate surges. (50 V nominal supply). My main supply caps (about 10,000 uf) were computer grade with Some V + some V surge. I don't remember the numbers.
I initially used 100 uf caps at 50 V on the board and they blew up.
