Triac fun
subzero349
I am trying to drive a 120VAC light bulb with a pin on a microcontroller.
I am using a Triac and Optocoupler circuit to try and do this...
I am using the circuit shown on Motorolla's MOC 3012 datasheet... (the triac I am using is a 2025 l6)...
I cannot get this circuit to work... any ideas???
Any suggestions for a better way to power an AC device with a microcontroller?
Without Your circuit cannot help....
My circuit always work. I've posted it to Projects section.
I couldn't find a website to post the image.. .I'll try and "draw" it
330ohm _moc3012_ 180ohm
5v o--/\/\/\------| |------/\/\/\---------------------HOT
TTL logic---------| | |
| | MT2
--------------__________ V^
|----- / |MT1
gate | RL
|-------/\/\/\/-----COLD
Darn... it took all the spaces out.... basically its TRIAC#1 cct at
http://ldp.kernelnotes.de/HOWTO/mini/Coffee-2.html
Sebi... thank you for posting the cct... I cannot get that circuit to work... I would bet my triac is not working the way yours works, or my light bulb is not resistive enough (125V, 1/2W power...)
Can you please tell me which TRIAC you used (the part number)
Eventually I will need this circuit to run an inductive load... but I thought I should first get it to work with a resistive load...
