JT Loveless
I'm sorry I didn't understand what you meant before. I do now. I think the pulley has an optical sensor on it because it's a white spot on the black pulley and the sensor is in line with it. But you gave me an idea. If I moved the sensor more toward the center of the pulley and put a white spot for it to read would that slow down the speed because it would be seeing it turn faster than on the rim of the pulley?The voltage I was referring to was the Power supply which originates from that off board power transformer.
It is 16v -17v then regulated down to 5v for the micro etc.
There is often a button magnet on the belt pulley, others have a opto sensor on the motor itself.
The 22v is what you would read on the motor at low rpm.
Max.
Thanks,
Jeff L.
