mindlessmalk
I have Eagle Light now, and I am ready to start playing with it. Send over the files whenever you can.
Thanks!
Nate
Thanks!
Nate
Boncuk said:What's so bad about charlieplexing? It helps saving copper.
If you add a capacitor across each LED then they will turn off fairly quickly because the output of a CD4017 goes low when the LED is turned off.Trevors said:Would it be possible to connect caps across some of the led's so they dim away rather than swith off quickly? If so, what values would be good? 100uF?
on1aag said:Hi Hans,
It doesn't matter how much your simulator costs if your concept is
wrong. When the counters are counting the leds will be charlieplexed
and they will still light, not as bright but they will light.
I think you gonna have to make a (few) minor modification(s) to your
design.![]()
on1aag.
audioguru said:Hi Hans,
Instead of three 555 oscillators you could use 3 inverters from a 74C14 Cmos Schmitt-trigger hex inverter IC.
The output transistors of the CD4017 will overheat without current-limiting resistors (or just a common one) with your very high 12V supply. A 9V supply is safer and the LEDs will be almost as bright.
For 25mA output I would use 74HC4017 ICs with a common current-limiting resistor and a 6V supply. They can be clocked with a 74C14 bunch of oscillators.
audioguru said:Hi hans,
You can make an astable from a single Schmitt-trigger inverter (6 in a package) or from two ordinary inverters.
