ajit_nayak87
I am trying uart serial communication on pIC16F886 . I am using 20Mhz external oscillator frequency.For below code i am getting garbage value.
i have tested similar code on PIC18F24K40 where i am using 16Mz internal oscillator where i can able to send and receive data with same hardware . Here i am replacing MCU with PIC16F886 with external oscilator
Please let me know any problem doing while intialization
I am using asyn mode.16bit
#include <htc.h>
#include <stdio.h>
#include<pic.h>
#include<stdint.h>
#include "delay.h"
#define _XTAL_FREQ 20000000
unsigned int i=0;
unsigned char c=0;
unsigned char ch;
#define SBIT_TXEN 5
#define SBIT_SPEN 7
#define SBIT_CREN 4
#define LED_RX RC7 // Pin assigned RX LED
#define LED_TX RC6 // Pin assigned TX LED
#define LED RC2 // Pin assigned for LED
#define DE RC5
#define RECEIVE 0
#define TRANSMIT 1
#define READ_REG 3
#define WRITE_REG 6
#define ILLEGAL_DATAVALUE 0x03
#define FALSE 0
#define TRUE 1
#define METER_ID 1
unsigned int j=0;
unsigned char* str;
unsigned int count = 0;
char data = 0;
unsigned char rxbuf[50];
unsigned char ser_data[95];
unsigned char crc_data[95];
unsigned char Max_scroll = 0;
unsigned char buff[10];
volatile uint8_t index = 0, rec_flag = 0, Delay_count = 0, Id[10], Buffer_count = 0, Cal_count = 0, Disp_count = 0, inc = 0, One_sec_update = 0, Auto_scroll_count = 0;
char data1[10];
unsigned char buf[20];
unsigned short int cnt, num,Dgt=0;
unsigned int j;
#define Notes_Index 25
unsigned int Toff_counter=0;
unsigned int POn_Flag=1;
unsigned int Poff_Flag=0;
void Serial_1_Send_byte(uint8_t trbuf1)
TXREG = trbuf1;
while(TXIF==0); // Wait till the transmitter register becomes empty
void Send_string_uart1(const unsigned char *string)
unsigned char i = 0;
do {
TXREG = string[i++];
while(!TXIF); // Wait till the transmitter register becomes empty
} while (string[i] != '\0');
char Serial_Receive_byte()
while(!RCIF);
return RCREG;
char usart_RxString()
while(*str !='\0')
{ // while not end of string
while(0==PIR1bits.RCIF);
RCREG = *str; // read next character
str++; // increment pointer to next character
return RCREG; // return the contents of uart
void UART_Init(int baudRate)
TRISC=0x80; // Configure Rx pin as input and Tx as output
// TXSTA=(1<<SBIT_TXEN); // Asynchronous mode, 8-bit data & enable transmitter
// RCSTA=(1<<SBIT_SPEN) | (1<<SBIT_CREN); // Enable Serial Port and 8-bit continuous receive
TXSTA=0b00100010; // Low Speed mode
RCSTA=0b10010000;
SPBRG = (20000000UL/(long)(64UL*baudRate))-1; // baud rate @20Mhz Clock
void UART_TxChar(char ch)
TXIF=0; // Clear transmitter flag
TXREG=ch; // load the char to be transmitted into transmit reg
char UART_RxChar()
while(RCIF==0); // Wait till the data is received
RCIF=0; // Clear receiver flag
return(RCREG); // Return the received data to calling function
void Timer1_Interrupt()
INTCON = 0b00000000;
PIE1=0b00000001;
PIR1=0x01;
TMR1H=0x0B;
TMR1L=0xDC;
T1CON=0x31;
TMR1IE = 1;
TMR1IF = 0;
// T1CON=0x01;
void Init_Controller()
cnt=100;
TRISC = 0x80; //RX port configured as input
PORTC = 0x80;
TRISB=0X00;
PORTB = 0X00;
TRISA=0X00;
PORTA=0X00;
ANSELH=0x00;
ADCON0 = 0b00000000;
ANSEL = 0b00000000;
Timer1_Interrupt();
LED=0;
//Below code make Ton and Toff time in equal Interval
void interrupt isr(void)
if(TMR1IF==1)
//EA60=45ms CB20 =107ms
TMR1H=0xEA; //load the time value(0x0BDC) for 100ms delay
TMR1L=0x60; //Timer1 Interrupt for 65000
TMR1IF=0; // Clear timer interrupt flag
Dgt++;
if( Dgt>=10)
// LED = !LED;
void Serial_1_Init()
BAUDCTL=0b01001000; //16bit baudrate has used
RCIE=1;
RCIF=0;
CCP1IE=1;
RCSTA=0b10010000;
SPBRG = 0x81;
SPBRGH= 0x00; // 9600 Baud Rate for 64Mhz
void EUSART_Initialize(void)
// disable interrupts before changing states
RCIE = 0;
TXIE = 0;
BAUDCTL=0X09; //16bit baudrate has used
// SPEN enabled; RX9 8-bit; CREN enabled; ADDEN disabled; SREN disabled;
RCSTA = 0x90;
// TX9 8-bit; TX9D 0; SENDB sync_break_complete; TXEN enabled; SYNC asynchronous; BRGH hi_speed; CSRC slave;
TXSTA = 0x22;
SPBRG=81;
SPBRGH=00;
RCIE = 1;
void main(void)
Init_Controller();
Serial_1_Init();
//UART_Init(9600);
/* GIE=1;
PEIE=1;
TMR1IE=1; */
while(1)
LED =1;
DelayMs(250);
Send_string_uart1("hello");
LED =0;
DelayMs(250);
