ULN2803APG question
I have connected 8x8 dot matrix to the breadbord with 2x 2803, and with 2x hc74595. That didnt work
And i have fiigured out why. When input on ULN2803APG is 5V, output is only 0.65V, and for matrix it should be 3V i think.
When i tried to connect only single ULN2803APG this way: PIN 1 and 10 to +5V, and PIN 9 to ground, output is also 0.65. Isnt it too low?
You have it mixed up, look at the schematic digaram in the datasheet. It is a low side NPN switch, so when input is 5V the output is grounded, otherwise it´s high impedance.
Shouldn't it be like a normal NPN transistor?
When base (input) is 1, output is +5V, and when input is 0, output is 0V
An NPN transistor doesn't do that.
With the ULN2803 when it turns on the output is connected to ground. 1 in, 0 out effectively.
Take a look at the datasheet for it and you will see the internal schematic, it's an NPN Darlington transistor with resistors so it can interface directly with a logic level ouput.
The ULN2803 has darlinton connected NPN transistors so its output cannot go to ground, instead it goes to +0.7V to +1.6V when its input is high.
Thank you all. I thought it is different. Now i have connected ULN2803 to catodes of my LED matrix, and it is working now. I guess i would need some other chip that can connect to +5V, like this drives to ground
