breakshift
Hey. I've started thinking about the possibility of designing a home-brew bat detector. I've researched the idea and I'm going to go for the most simple design, the heterodyne, to begin with. This design is essentially as follows: a transducer picks up the signal, before it is amplified and fed into a mixer to convert it down into the audible range. The user can then 'listen' to what's going on in the ultrasound range. The user tunes the local oscillator in order to scan through the ultrasound band.
So I thought I'd start at the start by looking at ultrasound transducers. This is where I could use some help and advice. Ideally I'd like to be able to 'tune' between 15kHz and 125kHz - but I can't figure out how to achieve this without spending a silly amount of money. I want to keep the cost down. From what I've read, I could go for:
1. Piezoelectric ultrasound transducer
Cheap, but narrow bandwidth. Possibility of increasing bandwidth (at the cost of sensitivity) by placing an inductor in parallel with it:
https://bertrik.sikken.nl/bat/detuning.htm
2. Electret condenser microphone - normally designed and specified for audio frequencies, with no specs given above 20kHz. However, apparently, these can sometimes offer some performance into the ultrasound. I have read that the following mic cartridge has some performance up to 60kHz:
https://www.electro-tech-online.com/custompdfs/2012/03/em06_wm61_a_b_dne.pdf
3. I've also looked at MEMS microphones, but again there's not much info given on their performance at 20kHz+ frequencies. For example:
https://www.electro-tech-online.com/custompdfs/2012/03/SPM0406HE3H-SBPDF.pdf
4. Electrostatic microphones apparently have good performance right up into the frequencies I'm interested in, but they require very high voltages to operate and I'd rather not go there.
https://bertrik.sikken.nl/bat/mics.htm
Since there's little information about higher frequency performance of electret condenser microphones I'm not sure if I could achieve my desired bandwidth with them. I could also consider using multiple piezo ultrasound transducers, but again not too sure how difficult this would be.
So if anyone could shed some light on this subject I'd appreciate it!
Cheers![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Cheers
