unable to find a 15-bit Binary Divider
Lac
I'm not able to find a 15-bit binary divider only 14-bit ones. Anyone know a way to make a 15-bit divider?
Thanks!
Lac.
huh?
What I really want to is to divide the 32 KHz clock signal from an oscillator down to a 1Hz signal.
A frequency devider is really just a digital counter. If you take your 14 bit devider, put a 4 bit counter on the output and just ignore the extra 3 bits.
Brent
Try this.
32768kHz on the input. 1Hz on the output.
STEVE
:shock:
Sorry, it's probably me....... :wink: but are you going to use a pic to display the digits etc? It's just that the post is in the microcontroller section, I thought you may be after some help with a micro-based clock.
Again sorry if I have got the wrong end of the stick :wink:
My fault.. I saw that i had posted it in the wrong section, but then it was too late. But anyways, thanks for help! :wink:
Cheers!
Lac.
