Muttley600
The guy is like a baby, picking up every toy in sight and even asking for ones on the shelves.
WHAT! You mean there's shelves with more on *grin*
What's on em
Don't forget we haven't covered phase or db properly yet
What's on em
Ok, differences between sim 2&3 caused by adding R
R has lowered the VP to 9.54 meaning there is less force
so it slowed the VP wave by 1m, hence changing the phase
I slowed to allow charge time for cap before carrying on as normal
hence not changed instantly but by slowing I wave down we have lost some output (by resistance) but charge time has resulted in phase shift too
Ok, does this alter the frequency then,
Giving us the db gain as its going in opposite direction to wave?
What other toys can I pick up, look, what's that one on the middle shelf.lol
By using VP I was meaning voltage potential, the energy able to move the electrons, is that the same as VG? It has to be the same (this is no longer a question) I need to start believeing what I'm saying
So I need to think of this as a time delay rather than speed of wave slowing down, I get what your saying![]()
(My emphasis)I also see why I needed to be able to see the three elements, there are differences, this is just the start time of a wave
(Emphasized addition is mine)So amplitude is power of signal
Frequency is how fast/speed of oscillations is over time/distance
Phase is time delay to start of wave
So we can set the height (width of spring coil)
Length of spring coil
& decide when to fire the starters gun on a wave or release the coil
Edit: determined by how much charge is allowed through the cap
See post #506.Phase is time delay to start of wave or how much charge before oscillation turns direction
So the cap is not only being delayed
but also how much it is allowed to resonant
We are about to come back to those five charge times you mentioned ages ago aren't we![]()
muttley said:So amplitude is power of signal
OK, here is a question for you:
Somewhere on the planet Earth, there is a place that receives 6 hours of daylight in a day. The amplitude just so happens to be the intensity of the AM 1.5 Global spectrum.
What is the frequency?
What is the duty cycle?
Showing your work is more important than a number. Units matter.
So, a term to say V & I for sim should of been?
So are you saying any load as a whole should be referred to as Watts
In the real world, your not fed the information you need.
I didn't expect you to get the frequency right, primarily because of lacking the concept relating to conversion of units.
