Unicorn+GLCD+Swordfish.
Pommie
Most Helpful Member
I finally got around to playing with the above combination and found at first it didn't work. I had a look through the GLCD module and found that INVERT_CS seems to be the wrong way around (in my mind) and GLCD_RST was not in the option section. After setting these it all worked as it should.
// Unicorn GLCD test
Device = 18F4550
Clock = 48
Config
   PLLDIV = 5,
   CPUDIV = OSC1_PLL2,
   USBDIV = 2,
   FOSC = HSPLL_HS,
   VREGEN = OFF
#option GLCD_DATA = PORTD        // data port
#option GLCD_RS = PORTE.0        // RS pin
#option GLCD_EN = PORTE.2        // EN pin
#option GLCD_RW = PORTE.1        // RW pin
#option GLCD_CS1 = PORTB.4       // chip select
#option GLCD_CS2 = PORTC.0       // chip select
#option GLCD_ASPECT_RATIO = 75   // aspect ratio, smaller number will squeeze y for GLCD circles and box
#option GLCD_INIT_DELAY = 100    // initialisation delay (ms)
#option GLCD_INVERT_CS = true    // invert CS lines...
#option GLCD_RST = PORTA.4       // reset line
Include "GLCD.bas"
Include "Arial.bas"
// program start...
ADCON1 = $0F                //All digital
CMCON = $07                 //No comparators
Cls
High (PORTB.3)              //turn on back light
GLCD.SetFont(Arial)
WriteAt(10,10,"Hello World")
GLCD.SetFont(ArialBold)
WriteAt(10,20,"Hello World")
line(10,30,70,30)
While(true)
Wend
End
One thing I did find which I think is a possible bug is the read from the GLCD (in module KS0108.bas).
Function GetData() As Byte
   WaitForIdle      // block until not busy
   TRISData = $FF   // set data bus to input
   GLCDData         // access display RAM data
   GLCDRead         // read mode
   StrobeEN         // latch data
   Result = DATA    // get the data
End Function
This toggles enable and then reads the port. It works but I think that is due to pin capacitance and on a more complex board it may fail.
hi Mike,
Do you know there is a Swordfish forum.?
Have you got the freebie or the fullversion.
EDIT:
David Barker is a nice guy, did some LCD tests for him last year with the Oshonsoft Sim
ericgibbs said:
hi Mike,
Yes, I have posted on there.
I've just got the freebie and have not even got near the limit of 256 bytes of ram. Actually, I lie, I went over it when I tried using floating point maths.
The little demo above uses 87 bytes of ram.
Thanks for the nice example Mike. I just received my TouchScreen GLCD with RGB backlight and am waiting on 25 pin machined pin SIP headers and sockets before I can start 'playing' too...
<update>
The machined pin SIP headers and sockets arrived. Yippee!
